1980s 1985 Vol. 11 Tokai Electric Guitars Catalog
PICKUP
A newly developed pickup that demonstrates 100% of the characteristics of F.V.X. The essence of technology created by the Tokai Project Team. A special pickup that combines an adjustable pin bobbin and a straight bar type bobbin. The magnet is made of ultra-high performance ferrite that has a strong coercive force and is not easily affected by demagnetizing fields. The wire uses 0.05% highest grade Cu. least resistance. It is wound onto an ABS resin bobbin using Tokai's original wiring machine (WM-1SP). 8000 times like hand winding. It is carefully wound at low speed. The sound is bright. A straight stand-up. Warm or powerful? This is a super advanced rock use pickup.
It is wrapped around.
The adjustable pin magnet can be adjusted to suit your sound style. Straight bar magnet eliminates sound loss caused by choking, etc. Perfectly supports string vibration
AYER'S ROCKERI
Adopts fine tuning system. Instantly adjust pitch after arming play. The long-awaited super mechanism. (F55-V55×55)
ROCK NUT
The string tension bar, which applies constant tension to the strings, is equipped with an integrated lock nut. A tension bar keeps the strings at a constant tension and is set on the lock base. No extra tension is applied when securing the strings with a lock nut. Therefore, the tuning (pitch) will not go out of order. Promises accurate fine tuning.
AYER'S ROCKER II
A speedy arm down that instantly reaches the 0 tension point. The reaction is also perfect. Adjustable pitch while playing. Dream space mechanism. (F65 -V65-X65)
PEG HEAD MACHINE
Tokai Kluson type pegs (equipped with F55-65 High precision double gear has no backlash (rattle). Smooth feeling. Perfect for the subtle tuning that players need most. Tokai Mini Rotomate IC Peg (equipped with V55-65) Mini type. Lightweight. Pegs have a big impact on the sound. Tension and weight balance have been considered, making it smaller than a regular rotomatic. Subtle tuning is also OK.
OUTPUT JACK
Easy to input guitar plug. Guitar cables don't interfere with your playing. Excellent durability. The best ergonomic position.
CONTROL SECTION
Simple control system in pursuit of operability 1 volume, 1 tone, toggle switch. The control system layout is in the best ergonomic position.
SHIELD
Electrical paint is applied inside the circuit. It is a special paint. Conductive paint shuts out noise. Eliminates the effects of internal circuit parts, external lights, and amplifiers. The shield is perfect now.
BODY
Thorough consideration of specific gravity and acoustic characteristics. Selected alder, adopted by Sen. The body has a bold cut. (By 1000% precision 3D router) Three dimensions body with sharp edge cuts. Light weight, sense of balance, playability, operability, and functionality are number one. Best match with pickup. (Sound quality characteristics depending on body style) You won't feel tired even when playing for a long time. It has unparalleled styling and performance. F Maximum effect on action play. Super advanced body. Sensitive V style body. F-star V: The boldest feeling on the straight. space. X: Sexual. Flowing styling. Unknown premonition X style body.
FINISH
F.V.X-65ASP ASRR is Tokai Originals Sparkle Flake. Complex diffused reflections occur due to lighting. Galaxy stardust. Beautiful and ever-changing staging. Special painting turns sparkle flakes into milky way. Super live performance.
NECK
Neck shape: Slim U-shape neck. No. 1 in branability. You won't feel tired even when playing for a long time. Enough strength. 400R fingerboard with selected rosewood. Rosewood has been used for a long time in classical guitars and high-end crafts. Beautiful wood grain. The fingerboard R is a 400R design with an emphasis on playability. Strength, bending and grip have been carefully considered. The long-awaited wide fret (2.7%). Tone sustain stabilizes and increases. Furthermore, 22 frets are designed for heavy guitarists. Triple effect with 400R fingerboard and wide frets. The possibilities for guitarists are endless. Sensitivity is 120%. Position mark: Dot position for F55-V55X55. Reverse Z style position for F65/V 65X65. Best match with total design.
HEAD STOCK
The headstock has been studied from basic aspects such as the weight of the peg machine, strength, tension, and the effect on the sound. The weight balance with the whole guitar is also perfect. The design is an advanced form.
F: Like the body design, sharp edge cuts. Wing cut headstock with a sense of space.
V: Super V headstock that follows the straight body form with a futuristic feel.
X: Long-awaited tension design for heavy guitarists. A heavy style headstock with hidden sensibilities.
●F55/F65
Body: Alder, Sen
Neck: Maple
Fingerboard: Rosewood 400R22
Frets: Fret Wide Frets
Peg: Kluson Type
Pickup: PU-12
Control: Volume, 1 Tone, Toggle Switch
Tremolo: 400R22
V55/V65
Body: Alder, Sen
Neck: Mable
Fingerboard: Rosewood 400R22 Frets
Frets: Wide Fret
Pegs: Rotomatic Type
Pickup: PU-12
Control: volume, 1 tone, toggle switch
Tremolo unit: (V55) Ayers rocker 1. (V65) Ayers rocker/lock nut equipped
X55/X65
Body: Alder, Sen
Neck :Maple
Frets: Fret Wide
Pegs: Kluson type
Pickup: PU-12
Control: 1 Volume. 1 Tone, toggle switch
Tremolo unit: (X55) Ayers locker (X65) Ayers locker II/lock nut equipped
(F55) Ayers Rocker (65) Ayers Rocker Equipped with lock nut
SUPER EDITION
SD
22 fret playability for all types of music. Explosion of new power!! Modern rock sound. Super edition with all coloring body.
SD40 / ¥40,000
●Body/Sen Alder
●Neck/Maple 1 piece/U shape
●Fingerboard/22 frets/400R rosewood
●Frets/wide frets
●P.U./VINTAGE MKII ×2
●Controls/1 volume, 1 tone, 3 Position selector switch
●Tremolo unit/bracelet/SS unit
●Pickguard/black 3P
●Peg/covered type
●Color/ASWR, ABR, AMRR ABBSR
SD40S/¥40,000
●Body/Sen Alder
●Fingerboard /22 frets/400R rosewood
●Frets/wide frets
●P.U./ST VINTAGE MKⅡ x2, VINTAGE MKII×1
●Controls/1 volume/2 tone/5 position selector switch
●Tremolo unit/press bridge/SS unit
●Pickguard/black 3P
● Peg/covered type
●Color/ASWR, ABR. AMRR ABBSR
PHOTO-41SD40S-ASWR SD40S-AMRR SD40-ABBSR SD40-ABR
SUPER EDITION
TST
A contemporary model with a humbucking pickup mounted. A “super guitar” with traditional style and the latest sounds. Full power!! Tremendous energy.
TST36H ¥36,000
●Body/Sen Alder
●Fingerboard/Rosewood
●P.U./DYNAMIC57×2 controls/Volume/2 tone/3 position selector switch
●Tremolo unit/SS unit
●Pickguard/ Black 3P
●Peg/covered type
●Color/ASWR, ABR, AMRRA BBSR
TST36HS / ¥36,000
●Body/Sen Alder
●P.U./SS-HOT ×2, DYNAMIC57 ×1
●Controls/1 volume, 2 tone, 5 position selector Switch
●Pickguard/black 3P
●Peg/covered type
●Color/ASWR A BR, AMRR. ABBSR
PHOTO (From left) TST36HS・ASWR TST36HS・AMRHTST36H-ABBSK TST36H-ABR
ORIGINAL MODEL
MBX
●MBX is the ultimate medium scale bass (Ultimate)
●MBX is a lightweight almighty bass
●The playability of the 24 frets is similar to that of a guitar.
●High quality almighty sound.
MBX45 / ¥45,000
●Body: Alder/Sen
●Neck: Maple 1 Piece Round Rosewood Fingerboard・24 Frets Medium scale
●PU: P7-11B (Split 1PU)
●Control: 1 Polyu Treble 1 Base
●Color: AB, AMR, ASW
MBX55 / ¥55,000
●Body/alder, Sen
●Neck/Map 1 piece round rosewood fingerboard 24 frets medium scale
●PU/Bass, dual sound
●Colors: AB. AMR, ASW
MBX70 / ¥70,000
●Body: Alder/Sen
●Neck: Maple 1 piece round rosewood fingerboard 24 frets (diam scale
●PU: P7-11B/P6-12B (PU) Controls/1 volume, tone, PU Balancer, dual sound system
●Colors: AB, AMR. ASW
●PHOTO from left: MBX45-ASWR/MBX70-ABR/MBX55AMRR
ORIGINAL MODEL
LBX
●LBX is long scale base
●The essence of the LBX is designed for professional bassists.
●Sustain Bridge Unit, a heavy sound produced by a long scale.
●3 types of control circuits (3 types can be selected depending on the playing genre) .
LBX50/ ¥50,000
Body: Alder, Sen
●Neck: 1 piece Round Rosewood
●Control: Volume Treble 1 Base
●Colors: AB, AMR, ASW
LBX60 / ¥60,000
●Body:Alder, Sen
●Neck: Mel LBX50/ 1 piece round rosewood fingerboard 24 fret long scale
●PU: P6-12B (humbucking IPU)
●Control: 1 poly bass dual sound system
LBX80 / ¥80,000
●Body: Sen
●Neck: maple 1 piece round rosewood fingerboard/24 fret long scale
●PU/P7-11B. P6-12B (PU)
●Control: Rume. Stone, PU balancer, dual sound system
●PHOTO from left LBX50-ASWR/LBX60-ABR/LBX80- AMRR
TALBO Electric Guitar with an innovative metal body
NEW TALBO with atomic number 13, element symbol AQ, and atomic weight 26.98154.
●World's first metal guitar (special alloy -T-ALLOY, researched and developed based on the element symbol Al) Good sound. Amazing quick response and long sustain.
●Completely shielded body
●Best matching with effectors, amplifiers, and PAs.
●AYER'S ROCKER I, equipped with a lock nut.
●4 new colors All-paint export model.
●All black neck & super joint Tokai AX-80S,
●Body: ¥80,000/Metal body (T-ALLOY)
●Neck: Maple 1 piece/Rosewood fingerboard
●PU/(S) P2-718×3. (D) P1-26BB×2
●Control/(S) 1 polymer , 1 tone 5 position PU selector, (D) 1 volume, 1 tone, toggle switch
●Peg/Crewson type (short post type)
●AYER'S ROCKER I. Equipped with lock nut
●All black headstock & neck
●Color: PW (pearl white) SG (Silver Gray) BR (Blazing Red) BB (Black)
TLS
The power of a variety of humbucking sounds.
TLS50-GT 50.000
TL560-CS 60.000
TL580-VF 80.000
TLS100-HS
TLC65-JS 65.000 Famous Player's Custom Model
TLC
Mahogany body unique sustain.
TLC60-OW 60.000
TLC100-BB 100.000
TSG
Light weight. solid guitar basics
TSG50-WR 50,000
TSG60-CH V60,000
TST
A timeless masterpiece. The heart of an electric guitar.
TST50-GSR 50.000
TST50-BB 50,000
TST60-Y50 v60.000
TST80-GS W80,000
TSTSSL-MRR 55.000 LEFT-HAND MODEL
TSS
Fat and powerful single coil sound.
TSS38-OWR 38.000
TS548-BB 48.000
TSS40-MRR 40,000
TSS50-SGR 50,000
TST50-BG-CRR 50.000 FAMOUS PLAYER'S FAVORITE CUSTOM MODEL
SUPER MACHINE BENDING
Super advanced mechanism. Create everything from fantastic vibrato to monster G sounds! An amazing tremolo unit that makes your music all by itself! The electric guitar equipped with SHIFT2001 is the newest in the world.
●Electric guitars with SHIFT2001 mounts do not have body processing holes. As a result, partial noise is eliminated and 100% of the original characteristics of the body material are utilized. You can enjoy clear sound from low to high range. SHIFT2001 allows vibrato while maintaining harmony.
●A super mechanism that allows you to adjust the bend amount (pitch change amount) independently for each string. Uses torsion ring.
●Amazingly long sustain with heat-hardened stainless steel rollers and roller play fine adjustment mechanism!! No wobbling.
●You can use ready-made strings as is. Changing strings is easy and quick. Fine tuner mechanism that achieves smooth and wide effects
●Uses ultra-precision miniature bearings for adjustment screws laid out in the best ergonomic position. Air angle adjustable. No arm lock brake required.
●SHIFT2001 tremolo unit (SHIFT2001 is an Answer Acoustic Lab product.
FSD-65S / ¥65,000
●Body/Sen Alder
●Neck/Maple Peace/U shape
●Fingerboard/22 frets 400R rosewood Frets/Wide frets
●P.U./Bar type humbucking P.U.×2
●Control/Volume・1 tone toggle switch
●Tremolo unit/SHIFT 2001
●Lock nut/E.T. Lock nut equipped
●Peg/Mini rotomatic type
●Color/ASWR ABR, AMRR, APPR
(PHOTO is prototype)
TFV-70S / ¥70,000
●Body/Mahogany
●Neck/Mahogany piston
●Fingerboard/22 frets/Rosewood
●P.U./FV-VINTAGE × 2
●Controls/2 volumes, 1 tone, toggle switch
●Tremolo unit/SHIFT2001
●Lock nut/SHIFT2001 Equipped with lock nut
●Big guard/Black IP
●Peg/Rotomatic type
●Color/SW,BB
SHIFT 2001
SV5-65/ ¥65,000
●Body/Sen Alder
●Frets/wide frets
●P.U./Part type humbucking P.U.×2
●Control/1 Volume/1 tone/toggle switch
●Tremolo unit/SHIFT2001 Lock nut/SHIFT2001 Lock nut equipped
●Pick guard/non-pickguard
●Peg/mini rotomatic peg
●Color/APWR (all pearl white), ABR (all black) AMRR (all metallic red) ), APPR(O Pearl Pink)
SD-65/ ¥65,000
●Body/Sen Alder
●Fingerboard/22 frets・400R rosewood
●Frets/wide frets
●P.U./ Part type humbucking P.U.X2
●Control/1 Volume/1 tone/3 position selector switch
●Lock nut/SHIFT2001 Lock nut equipped
●Pickguard/Black 3P
●Peg/Mini Rotomatic type
●Color/APWR, ABR AMRR APPR
SD-65S / ¥65,000
●Body/sensor Alder
●Frets/wide frets
●P.U./ Bar type single coil P.U.X2, part type humbucking P.U. 01
●Pickguard/Black 3P
●Color/APWR.ABR AMRR APPR
PHOTO SVS65-APPR, SD65S-APWR, SD65-ABR
TTE
Delicious old feeling. Terry model.
TTE50-BLR 50,000
TTES5-N 55.000
TTE55L-BL 55.000 LEFT-HAND MODEL
TTE70-PR 70.000
TTE50-BLR 50.000
TPB
A masterpiece of public bass. Hard puncher.
TPB40-BBR 40.000
TP845-MR 45.000
TPB50G-ABR 50.000
TPB55S-ASWR 55.000
PJ55-ABR ¥ 55.000
TJB
from fusion Until the lock. The ultimate super technical base.
TJB45-OWR 45.000
TJB45S-MRRH 50.000
TJB55G-ABR 55.000
TJB70J-YSOR 70.000 FAMOUS PLAYER'S FAVORITE CUSTOM MODEL
TFV
TEX
TFV50-BB 50.000
TFV60-MS 60.000 FAMOUS PLAYER'S FAVORITE CUSTOM MODEL
TFV70-YN ¥70.000
TEX70-BB 70,000
Ayers Rocker Mount F.V.X is a space mechanism that realizes unprecedented weightless arming play.
AYER'S ROCKER I
mounted on F55, V55, X55
●A super mechanism that allows you to instantly adjust the pitch after arming play by adopting a fine tuning system that is not found in normal tremolo units.
●The fulcrum is rounded and constantly rotates in response to arming operations. Eliminates irregular and unstable arming operations that could not be resolved with the traditional model. Sustain is always obtained because the contact area is constant in all arming conditions. (Round edge style)
●You can attach strings from either the front or back side.
●The fine tuning knob is laid out at the rear to avoid contact during braking. Arming width that produces aggressive guitar sounds.
●Easy mount arm that can be easily attached and detached. Arm torque can be adjusted. Comes with one nylon spacer so it won't damage the arm. Smooth rotation.
●Of course, octave adjustment and string height adjustment are OK as long as they are tuned.
AYER'S ROCKER II
mounted on F65, V65, X65
● Speedy arm down that instantly reaches the tension point. Reactions are also quick. Tuning pitch deviation is also minimal.
●Octave adjustment and string height adjustment are possible even when the instrument is tuned. There is no need to cut the ball end of the string; it can be used as is. The entire bridge is locked using the bridge lock method. There is no play or rattling in the front or rear or lateral direction.
●The fine tuning knob allows you to adjust the pitch during play. The moderate torque completely prevents pitch deviations caused by contact during play. The super knife edge stud bolt system dramatically increases arming reaction accuracy. (Smooth arming) The overall height of Ayers Locker II can be adjusted using stud bolts. Easy attachment/detachment, easy mount arm. Arm torque can be adjusted. Contains a nylon spacer so it won't scratch the arm. Smooth rotation.
●Amazing mechanism, design/utility model pending.
●F65-ASWR: ¥65,000 ●F55-ABR: ¥55,000 ●F55-ACRR ¥55,000 ●F55-ABBSR: ¥55,000
●V55-AMRR ¥55,000 ●V55-ASWR ¥55,000 ●X55-ABR ¥55,000
●Color:
(F55) ASWR (All Snow White) ABR (All Black) ACRR (All Candy Red) ABBSR (All Blue Black Sunburst)
(V55) ASWR (All Snow White) ABR (All Black AMRR (All Metallic Red) ), ABBSR (all blue black sunburst)
(X55) ASWR (all snow white) ABR (all black), AMRR (all metallic red) ABBSR (all blue black sunburst)
(F65) ASWR all snow white), ABR (all black) ASRR (all sparkle red), ASPR (all sparkle purple)
(V65) ASWR (all snow white) ABR (all black) ASBR (all sparkle red), ASPR (all sparkle purple)
(X65 ) ASWR (all snow white), ABR (all black) ASRR (all sparkle red), ASPR (all sparkle purple)
●Specifications and prices are subject to change without notice for quality improvement.
●The color of the product may differ slightly from the actual product due to shooting conditions and printing characteristics. As of December 1, 1984
