Peter Mac said:
Hi Jacco,
Mac Seshimoto from Tokai Gakki, Japan told me in 1985 that the 1983 and 1984 TLS-200 were available with Brazilian fingerboards.as a special order guitar. As to how many had them he did not say.
The serial number puts this guitar well before the 8003000 mark, when Tokai started the dating stamp, so it would be in the first half of the year, maybe even the first quarter. That's why I said early '78.
Earliest code I have for 1978 is a SilverStar 8000144, and 8000382 for an LS.
Peter
Thanks for the info on the braz board 200s Peter, didn't know that. That most likely means all other Tokai LPs before 1985 did not have a braz board as we already thought.
About the serial number and your conclusions;
I thought I already had proven that Tokai didn't serialize their guitars right after completion.
If we look at 1978 up to 80019xx there is a mix of LS, ST, SS & PB models. Then a few hundred LSs and from around 80022xx up to around 80043xx no LSs anymore, only Tokai Fender models.
This is a similar pattern as seen in in 1979-80-81.
If we take 1979, the last LS is 90063xx and this one has a december production stamp in the neck cavity.
There are however 3500 Tokai Fender models produced after this one according to the serial number log, for the last one is around 90099xx.
In this range of 3500 however there are examples with date codes going back to july. So these were produced earlier but serialized later.
You can check that for yourself for I know you have many pictures of ST models with date stamps.
So going back to this 1978 GT with serial 8002006.
The last LS from 1978 logged is 800216x.
The first LS from 1978 logged is 800010x.
That tells me very late 1978, november or december.
