A
Anonymous
I prefer Ronnie's.
stratman323 said:I prefer Ronnie's.
Bluefinger said:Ronnie Earl? The King of guitar faces
stratman323 said:Bluefinger said:Ronnie Earl? The King of guitar faces
No, BB King is The King of guitar faces.
stratman323 said:Or maybe Gary Moore?
Bluefinger said:I have all my p90 guitars and some humbucker ones wired out of phase.
stratman323 said:Anyway, back to pickups.
I assume that only having a 2 conductor cable doesn't cause problems when the P90s are out of phase? Because when it's out of phase, the outer braided cable becomes hot, & the hot wire becomes the ground.
I know that can cause problems on metal covered HBs, but are plastic covered P90s OK?
stratman323 said:But if you flip the magnet, you lose the option of having the pickups in phase - that's no good.
Mick51 said:Exactly. So, that's why P-90's need to be RP / RW when they are wound.
stratman323 said:Mick51 said:Exactly. So, that's why P-90's need to be RP / RW when they are wound.
Sorry, I don't understand that. I have the Tokai P90s wired through a push/pull pot to give me in phase/out of phase. What's wrong with that?
stratman323 said:Hum doesn't bother me - I'm used to Strats.
:lol:
My Bare Knuckles have arrived. The only problem I can see is that the Tokai pickups are plastic wrapped around the ground wire. The BKs just have bare braided wire around the central core. So if the two bare wires touch in the control cavity, could that cause problems?
Also, I can't get the b*$%!@ neck pickup to come out of it's hole, even after removing the two screws. :evil: Do Tokai glue them in place?
Bluefinger said:Yup, non isolated pickups will cause problems ... complete silence to be exact :lol: . You'll need to isolate it first with shrinking hose.
They should come out rather easily. What if you pull on the pickup covers? Do the covers come off at least? Strange ... maybe you should bang the guitar against a concrete wall a couple of times ... that should do the trick
Bluefinger said:BTW ... you have an LS85S, right? This is the proof that they have different pickups than the LS160S. Mine has non isolated pickup wires.
stratman323 said:Bluefinger said:BTW ... you have an LS85S, right? This is the proof that they have different pickups than the LS160S. Mine has non isolated pickup wires.
Correct. I'm not surprised to hear that - most things on yours are supposed to be upgraded versions of what I have on mine, better pickups, caps, pots, switch, tailpiece etc. Thats why the 145/160 costs a lot more money!
