A
Anonymous
It looks like they've been there for a while!
stratman323 said:It's a Les Paul, so I'm not sure about anything!
You mean one of these will fit the Tokai scratchplate, & still be slimmer than the Tokai rings?
http://www.wdmusic.co.uk/category/Hardware___Parts/Pickup_Rings___Covers/Plastic_Pickup_Mounting_Rings
dombat said:The WD low rings dimensions:
Overall size - 89mm x 44.5mm. Depth - 2.5mm up to 5mm.
Centre to centre of the two Humbucker mounting holes - 77.5mm.
The axetec ones are bigger: http://www.axetec.co.uk/pumr01 dimensions 02.gif , that's why they don't fit
dombat said:By the way, why do you want archetop rings on an LP?
I've always used flat on mines, they look nicer, with a very light bendig of the ring.
May be your LS top is rounder than mines.
Archetop rings are for archetop guitars: 335 type. Even on my ES, the neck ring is better flat than arched.
DaveWW said:Mike,
I think you know thjis but just in case. LP pickup rings are flat bottomed but tapered. Both pickup rings get thicker towards the bridge.
stratman323 said:I've just been to check, & I was wrong - the Tokai rings are flat-bottomed. Well that might explain the 2 problems - 1, the rings were too high to allow the action to be lowered to where I wanted it. And 2, why one of the rings was split when I got it!
What do other LP owners use?
