warxy said:
what if i compare the ALS43/48 with a Epip LP standard? sounds like the epip got better wood :-?
That is exactly what you need to do. Then YOU can tell which one SOUNDS like it has the better wood.
The Tokai is a basswood body with a maple neck. Fact.
The Epi, depending on where you look, is supposed to be Solid Mahogany with a Flamed Maple top and a Mahogany neck, just like the real thing, if you believe in Leprechauns. Mahogany/Alder body and Mahogany/Alder top with a Mahogany neck is another selection. WTF is Mahogany/Alder? Is the word "Laminated" supposed to be mentioned?
Epi state that this is "Mahogany" but is actually (Laminaticus Cheapandnastius), so yes, if you want to believe they got the better wood.........
http://www.guitargear.net.au/discussion/index.php?topic=13572.0
An Epi will be either Alder or Basswood, with a Maple neck.
Check the neck for a scarf joint behind the 1st to 3rd frets. The Tokai and the Epi will be the same.
If you think you are getting Mahogany, look at the back of a Japanese Tokai, or a Gibbo and compare the grain to the Epi. The Epi will be different.
If you want an Epi, go for it. Look at the thread about a Springysound by kitarist. He was not sure about his first Tokai.
Now he knows.
Hope Santy puts something nice in your Xmas stocking.[/i]
