togps said:Here is no censorship. Is'nt it?
Ozeshin said:we are discussing the tuner issue as a general topic we'll be fine.
The issues were not that they were not in a straight line, but the spacing was out between most of them. If there was a 5mm gap between the Bottom E and A then the others varied between 2mm and up to 8mm.Jamieh said:I just checked all the 3-a-side Tokais that I have in stock and NONE of them have tuning machines in a straight line. .
Walnut said:The issues were not that they were not in a straight line, but the spacing was out between most of them. If there was a 5mm gap between the Bottom E and A then the others varied between 2mm and up to 8mm.Jamieh said:I just checked all the 3-a-side Tokais that I have in stock and NONE of them have tuning machines in a straight line. .
They were on the twist and in most case's ( of the ones I looked at ) the holes were not drilled in equal spaces.
I will not mention any names for obvious reasons.
bruceboomstick said:I will not mention any names for obvious reasons.
One particular company springs to mind - when I read that post I had to cough their name. Hope it didn't sound like one of their coughs or I might be sued.
bruceboomstick said:This is just a theory, but I reckon the heads following the radius of the head stock is easy to explain. Hole drilling always requires a datum point - ie a fixed point to measure the distance to the centre point of the hole from. Easiest place to measure from is the side of the headstock - if you keep the distance constant (which is the easiest thing to do) the middle tuners will be inset. In tradtional wordwork you'd make a simple rule and say drill x distance from the edge and that translates really well to modern boring machines. If it's any good for tuning I wouldn't want to speculate, but from a drilling perspective it makes sense.
Just a theory - be interested if anyone wiser than me (and let's face that's pretty much anyone) has any other ideas.
