Aria By TOKAI
Anyone recognize this body?
Aria?
Tokai type code stamps
check bost
Specifications: 91 Aria pro? MA-650S body.
It will be the middle class body of the Magna series made in Japan.
The Magna series has changed slightly, but this is the model introduced in 1991.
The main features were a see-through finish with a non-locking bridge, roller nuts, auto-locking pegs, and a sensor body, and it was a model that was strongly influenced by the AQ series that was introduced earlier.
This individual has a slightly rare natural finish.
It's not unpainted, it's a gloss finish.
Manufactured by Tokai Gakki, the main model of the Aria pro? made in Japan at this time was mainly made by Tokai Gakki, so the construction of each part is very good.
It is made by Tokai Gakki, and the parts are mainly made in Japan such as GOTOH parts, making it a very cost-effective model.
Specifications
The body material is Sen 3 piece.
The body shape is a thin body with the top and back removed boldly, and although it is lightweight and very playable, it is quite heavy for MAGNA, at 1.75kg, probably because of the body material.
The neck has a slightly protruding 24 fret regular scale (648mm).
The bridge is compatible with GOTOH's LFT-10 bridge, and the bridge counterbore is also compatible with that bridge.
Between studs is about 69mm.
Please use 6mm studs.
The control part corresponds to a slide switch, 2 pots, and 1 mini switch.
The joint is a joint that uses a hat-shaped bush.
Size: The size of the neck pocket is 56.3mm wide and 17.8mm deep.
Color: Natural.
Condition: There are some small scratches, but they are not so noticeable, and the body is beautiful because it does not have a bad feeling of use.
There is a thin darkening on the bottom of the body, but it seems to be on the wood itself, not on the body.
Recommended point: Tokai Gakki's MAGNA body is well made, but the bridge is a bit restricted, so a special bridge is a must.
A mailing cost becomes Yu-pack 100 size.
The neck of the same color head is also exhibited.
check bost
Specifications: 90's Aria pro? MA-650 body.
The Magna series has been slightly modified, but this is the initial model.
It is made by Tokai Gakki, and the parts are mainly GOTOH parts and Japanese parts, making it a very cost-effective model.
Also, this series has a lot of 2-tone burst colors, so monotone is quite rare.
Specifications
The body material is alder.
The body shape is a thin body with the top and back removed boldly, and it is lightweight and very playable.
Floyd license bridge (ART-2 made by GOTOH) is supported and the distance between studs is 74mm.
The control part is a type that uses three mini switches.
Size: The size of the neck pocket is 56.2mm wide and 17.4mm deep.
Color: Black.
Condition: There are some minor scratches on the whole, but this is not a serious damage and I think the degree is so-so.
There is a rear strap pin relocation hole.
Recommended point: Well-made MAGNA body made by Tokai Gakki.
