1980s 1986 "Carbon Fiber & FRP" Ad
Carbon Fiber & FRP
M・A・T is a future-ready advanced electric guitar that uses carbon fiber and FRP. New sounds from Tokai
Carbon Fiber:
Carbon fiber is stronger than piano wire or steel and does not deteriorate over time. It features high vibration absorption and clear sound. The coefficient of friction is small and finger work is smooth. It is also revolutionary in terms of playability, as it has a small specific gravity, is light, and is easy to balance. Please check out Tokai's new reach, the amazing expressiveness of carbon fiber's material properties.
FRP:
Abbreviation for Fiber Reinforced Plastics. The FRP body has excellent impact resistance, heat resistance, moisture resistance, and chemical resistance, and overcomes defects such as thinning and slight irregularities that cannot be avoided with a wood body.The FRP body has a powerful and sharp feel that will last even after long-term use.
Please check out Tokai's new sound that is compatible with the material revolution of electric guitars and the future music scene.
FRP body & carbon fiber neck model
CM-801/802
¥80,000 (released in March)
●Body: FRP
●Neck: Carbon fiber neck (Adopts a tension wire mechanism: A mechanism that maintains a constant neck condition by balancing the tension of the strings with the tension wire mounted inside the neck.
●Pickup: M・A・T original single Coil type x 3,
●Control: 1 tone, 1 toggle switch
●Bridge: tremolo unit: M・A・T original high grade tremolo unit mechanism. (patent pending)
●P.U. (801) (802) M・A・T original humbucking type × 2
●Controls (801) 1 volume 1 tone/5 position selector switch (802) 1 volume
●Color: SWR (Snow White) BBR (Black) TRDR (Torino Red)
●Carbon fiber body & neck model (Scheduled to be released in April)
M-2001/2002
Y 200,000
●MAT original P.U equipment
●Control: 1 volume ・1 tone ・1 preamp control (active times ) Coil tap or plus 1 sound
●Bridge: MAT original tremolo unit M-2501/2502 ¥250,000
●Top-grade P.U. equipment designated by the project team
Top quality control circuit
M・A・T original tremolo unit
●PHOTO is prototype (left) FRP body & carbon fiber neck model CM-802 (right) carbon fiber body & neck model M-2002
●M・A・T catalog request: Acceptance starts from April 1st. Please enclose a 250 yen stamp and write your number, address, name, age, occupation, and telephone number at: Tokai Musical Instrument Manufacturing Co., Ltd. RF4, 36 Terawaki-cho, Hamamatsu City, Shizuoka Prefecture 430 in.
