Hi Folks,
I'm Finally in the Market For a Tokai LP standard.I've been searching locally here in Australia.I've found 3 that I'm tossing up between.
The first one and favourite so far is listed as a 1985 LS-80.I've searched the registry and gone in armed with as much info as I can.
Here's what I've found. It's serial number says it's an 85 model,There is no marking on the fretboard,the top is lightly flamed .I was allowed to pull the pickups and with magnifying glass cannot see the laminate.It looks to be a solid flamed maple top.The neck tenon stops at the pickup cavity and doesn't continue under the cavity.There is no stamps or markings in the cavities whatsoever.The neck pickup has a gold bass plate and no markings.The bridge pickup is a Seymour Duncan JB.The pots have been replaced with genuine Gibson pots and the caps are the old genuine bumble bees
The seller assumes it's an LS-80 but I'm starting to think otherwise.What do you experts think.
The other 2 guitars are an all original LS-50 reborn old with a 2 piece body and 2 piece top, and a 1996 LS-60 all original with a one piece body and a 2 piece top.
They are all similarly priced with the LS 80 about $200 aussie Dollars more than the other 2,They are all cherry sunburst.
Could you folks tell me what you think and which one you'd go for.I've only played the LS-80 and it feels awesome.the finish seems to be nitro like my vintage strat.
Thanks heaps
Watto
Thanks heaps
Watto
