Hi Guys
The two guitars are quite similar generally speaking.
Even I have had difficulty splitting out the differences and have had little info from Tokai other than what is publicly available.
The LS1000 is essentially the same as an LS150 with upgraded inlays etc etc. Both should be nitro finish guitars.
The 230 has increased quality flame top for sure in general. They are all different so we take pics of each to show the tops.
It features PAF MK2 pick ups - same as the vintage range. The base specifications appear very similar however. The condensers in the 230 are black beauty for sure as we've had the backplate off and taken photos for another customer.
The main issue, if you are trying to work out which to go for, is availability.
From what i hear getting hold of the good maple tops for LS150 is a bit of a nightmare and expensive. I think they occasionally get a few tasty pieces which are reserved for LS230 and LS370/470 and that's why we get a couple of these turning up now and then. You don't really see a duff LS230 top, the LS150s have been brilliant to "ok"...from the distant reaches of my memory!!
:roll:
The last time we had any flame top LS150 was back in 2007 (i think), LS1000s arrived around christmas time, and we've just had a trickle of LS230s turn up.
You're pimping your ride slightly with a 230, the 150 is a cracking instrument which generally has the edge in terms of value for money The problem is you can't basically get one.
The 230s you'll fall in love with the maple tops....and it's as good as a second marriage!!
Just my two cents.....i'd love it if tokai finally did a comprehensive web site which had all the minutest of specs on it.
OH - and the LS150 technically is available in more colours then the 230 which is HDC or VF only.
