Tokai Pbass identify
pkavpro
I found another Tokai in our local shop.
P bass with only "Tokai' label on headstock
Please help identify its authenticity.
Thanks
The year made is still up for debate. 1983-1985 it seems.
The model is not as easy to pin down.
It is below the 60 level since it has 3 screw tuners.
1984 catalog:
TPB Series
TPB40 / MODERN MODEL / ¥40,000 Powerful sound of super-heavy class, unparalleled playability. Special hardware is the best area for beginner class base. It is a model born in pursuit of high cost performance. A masterpiece dedicated to rockin' bassists.
TPB48 / MODERN MODEL / ¥48,000 Slim 1-piece maple neck for dynamic base running. The tight and deep bass produced by the split-type pickup is worthy of the name of a hard puncher. The pinnacle of middle-class bass with almighty expressiveness.
TPB50 / MODERN MODEL / ¥50,000 Unique special metallic color that supports wild stage action. Dedicate powerful sound to live musicians.
TPB60 / MODERN MODEL / ¥60,000 A one-piece maple neck that promises reliable and stable fingering, and a lightweight waist-cut body that won't fatigue you even after playing for a long time. A wide range of well-balanced sounds, from rock to fusion. The definitive technical base.
TPB50V-GS / 1959 MODEL / ¥50,000 A highly anticipated new item from the oldies series. A high-grade sound that perfectly expresses the bassist's sensibility as well as being lively. Vintage model
TPB50V-OWR/1964 MODEL / ¥50,000 Old reverse wound pegs, elegant silver logo, and tortoiseshell pickguard perfectly reproduce the feeling of the 1960s. An oldies model with a tight, sharp, and heavy sound.
TPB80V-GS / 1957 MODEL / ¥80,000 The pinnacle of TPB vintage models. Hard Rock maple 1-piece neck, alder veneer carved body, and newly developed PB vintage pickups reproduce the old-fashioned sound. A true original bass that is extremely old.
TPB80V-YSR / 1960 MODEL / ¥80,000: Hardware and parts that recreate the original version. We guarantee the highest level of play performance.
Looks like the metallic red paint makes it likely that it is a TPB50 MR
The 40 and 48 did not have that color as an option in 1984, which is around the time this bass was made.
Also it has 3 screw tuners so not a 60.
Do you have any pics of the pots? They may have a date code on them.
You're welcome.
Here are the specs from the 1984 catalog.
Looks like it has a U neck.
I am thinking this was made in early 1982 and had a spaghetti logo that was changed. It may have been one of the guitars seized by Customs in the UK?
Hard Puncher Six Digit Serial Number 10xxxx Gallery
Spaghetti logo
100591
102058
103979
104814
104898
Script logo
100818 (early 1982 with changed decal??)
106725
107065
107233
107291
107972
108398
108581
108761
108783
109131
109761
109858
Considering the serial number, the 3 screw tuners, and the MR color I would guess it is a 1982 PB50 MRR.
1982 catalog
