P1-11 BZ "Flying Dragon" Pickups
Introduced in 1983.
High output ceramic pickups.
Have a removable black plastic cover with the flying dragon logo embossed on it.
Resistance: 18.1 - 18.2k Ohm
They originally appeared in VX, TZ, FSD, FVD, and EXD guitars.
1983 mid year catalog translation:
New humbucking P.U. P1-11 BZ
Thorough research on old guitar pickups has created a humbucking pickup full of originality.
Mounted on all 5 series models of VX, TZ FSD, FVD, and EXD, and mounted on the black cover of the exquisite Flying Dragon, please experience the splendid and exciting original sound.
(P1-14BZ with 4 core shield is used for models with dual sound system and coil tap system)
Tokai トーカイ P1-11BZハムバッカー カバー付き... - ヤフオク!
Specifications: This is a humbucker that was mounted on the rear of the 1983 Tokai FSD-65. It was a TOKAI original humbucker, which was a limited model at the time and was installed in the upper class with a list price of 65,000 yen, with the part number P1-11BZ. According to the catalog at the time, thorough research on old guitar pickups gave birth to humbucking pickups full of originality. Please realize splendid and exciting sound... apparently ... It has a cover, but it can be removed. It's a ceramic humbucker. It looks like a normal PAF humbucker, but it actually has a resistance of 18.21kΩ. Also, the build is very good, and it is different from the mass-market model. String pitch is about 10mm. Originally it was a model with a plastic cover. The length of the lead wire is about 20 cm. Condition: There is no particular feeling of use and it is beautiful.
Tokai Super Edition Stratocaster - 80’s Vintage Guitar, Made In Japan / MIJ | eBay
Seller's description:
Has had some modifications in the past. Very high gain output, fast fretboard, chunky frets. Features Kahler made in USA locking tremolo system - Unfortunately I’ve misplaced the arm and Allen key. Comes in a plush Hiscox case. Built in the era that Tokai were out performing Fender as a hybrid between a classic Stratocaster and a metal style guitar. Very rare & collectible - Great value vintage guitar.
Uncovered
◆ Description ◆
Used but in Good condition.With No Case included.The pickup cover is removed, but the original pickup cover is included.There are hints of usage such as scratches and dent marks, but it does not affect musical performance.Please see pics for reference.
◆Spec◆
Body: Alder or Sen
Fingerboard: Rose
Neck Material:Maple
Scale:
Fret: 22
Pickup:Tokai Original Humbucker P1-11BZ x 2
Model Year: 1983
Weight:3.6kg
Color: White
Tokai FVD-50 Flying V Type Japan 1983 Electric Guitar | Reverb
Tokai トーカイ P1-11BZハムバッカー ゼブラ セ... - ヤフオク!
Specifications: Humbucker mounted on the rear of the 1983 Tokai FSD-70.
It was a TOKAI original humbucker, which was a limited model at the time and was installed in the upper class with a list price of 70,000 yen, with the part number P1-11BZ. According to the catalog at the time, thorough research on old guitar pickups gave birth to humbucking pickups full of originality. Please realize splendid and exciting sound.... apparently ... Originally it had a cover, but it looks better without it, so it seems to have been removed. Zebra style ceramic humbucker. It looks like a normal PAF humbucker, but it actually has a resistance of 18.10kΩ. Also, the build is very good, and it is different from the mass-market model. String pitch is about 10mm. Originally it was a model with a plastic cover. The length of the lead wire is about 20 cm. Condition: Originally a covered humbucker and just removed before shooting, so the pole piece is also shiny. Mounting screws and springs are included.
VX65 PGR
Tokai VX-65 Original Series Electric Guitar | Reverb
Scale 25.5 \"
Neck mount: Bolt-on
Body: Alder
Neck: Maple
Fretboard: Rosewood
Number of frets: 22
Tuners: Deluxe
The radius of the fingerboard on the first fret is 7.25`
The width of the fret is 2.5 mm. (Medium)
Controls: 1 volume control, 1 tone control, 3-position switch
Scale 25.5 \"
Neck mount: Bolt-on
Body: Alder
Neck: Maple
Fretboard: Rosewood
Number of frets: 22
Tuners: Deluxe
1983 VX55 MRR
Japan Vintage Tokai VX-55 1983 | Reverb
Body – Alder
Neck (bolt on) – Maple/Rosewood
Number of Frets – 22
Width of Frets (Fret Size) – 2.5 mm
Tuning Machines – Gotoh Deluxe
Neck Width at 1 Fret (mm) – 43
Neck Width at 12 Fret (mm) – 52
Neck Thickness at 1 Fret (mm) – 22
Neck Thicknes at 12 Fret (mm) – 24
Fingerboard Radius First Fret – 7.25``
Fingerboard Radius Last Fret – 7.25``
Scale Length – 648 mm
Pickups – Original humbucker with push/pull coil split on the tone knob for single coil and humbucker sounds!
