Six Digit Serial Numbers Starting With 01xxxx 1991 1992
The neck and body dates are all out of sequence on many of these unlike earlier years. Could this be indirect evidence of using up old parts in advance of shifting to producing Fenders???
These 01xxxx serial guitars seem to date from the early 90s.
Perhaps 01xxxx is 1991 ?
Also interesting to me that the ST models are typically low cost Strats. ST30/40/50 range.
HSS bodies are common
Pickups are typically low spec. Ceramic pickups or pickups with light gauge red white and blue lead wires.
Mystery 1990s Single Coil Pickups TOS1K or MKIII ?
Logging serial numbers:
Engraved pots with dates:
013852 Pot date March 1991 TE80A
014302 Neck date November
014338 Pot date May 1991
014405
0144?? Neck date November
014714 Custom Edition Tele
014937 Custom Edition bass
Ink stamped pots:
014984 Body date May. Ink stamped pots
014999 Ink stamped pots. Custom order TST?
015144 Pot date July 1990, Neck date May, Custom Edition AST, Pots out of sequence
015379 Neck date January, Ink stamped pots, TST50 ? Neck date out of sequence.
016956 Custom Edition AST
017304 Neck & body date October. Ink stamped pots. SSS
017336 Custom Edition AST
017579 Neck and body codes August. TST50? 60?
017631 Custom Edition
017698 TE80A
017882
017895 Neck date June, Ink stamped pots
018119 Neck date June. Ink stamped pots
018440 Neck date January, Ink stamped pots
018854 Custom Edition AST
018882 Custom Edition AST
ST50YS ?
SN 015379
Help identifying a legit/fake MIJ Goldstar
1994 catalog
"Export" models
ST50N ?
HSS, Fender headstock, 6 digit SN, - instead of =.
S/N 017895
Strange Goldstar.Just what is this?
tokai
N.E 7ok'll Do said:
Hi all,
I have one of these, exactly the same but a lower serial number.Cracking guitar. Has a two piece body, Final Pro Spec saddles and Kluson style machines without the Deluxe stamp (same as my 1990 flying V).
I agree that the routing is not typical to an 80's Goldstar but the single coil routs are the same as my Goldies with the later VII pickups and the humbucker very similar to those found on Super editions. Mine still has the same MIJ sticker on the neck ,in the same place as the 80's Goldies, just in front of the neck pocket. Also the counter sunk holes for the neck screws and the couple of small holes in the centre of the neck pocket are exactly the same as 80's Tokai's.
In my opinion 100% Tokai ,but a later model, I'm thinking early 90's maybe later ?
Help rare Tokai Goldstar Sound
1994 catalog
"Export" models
AJB55
This seems to help some in dating these.
Same "S" mark in the neck pocket as the natural HSS Goldstar in post #3 of this thread (SN 017895).
And one digit away from post #2... Also has an "S" mark...
SN 015380
Tokai AJB-55 1994 Natural | Reverb UK
SN 016956
HSS AST40 ?
Hard to read, but definitely starts with 01xxxx
TOKAI junk CUSTOM EDITION | eBay
Serial number 016956
Versatile model with SSH layout.
VOL TONE worked. Comes with a tattered case.
20210525 At the time of inspection, there was a sound in all selector positions.
The truss rod is loosened a lot, and there are places where the fret side is floating. Arm is missing.
