Waddy Peytona
Active member
I'm replacing the pickups (SD '59s), pots (CTS), and caps (orange drops) in my ES120. It appears that the CTS pot posts are larger than the original posts so I need to widen them to 9.4 mm. I've never done a mod like this before...fortunately for me I have a good friend who is an electrical engineer who is happy to help with the wiring and soldering.
Before I drill out the existing holes I thought I'd consult the wisdom of the forum...those of you who have done a similar mod...did you drill with a 9mm bit and then rasp out the extra .4 mm? And did you take any precautions to prevent chipping of the finish?
Thanks.
Thanks.
