how do you tell witch factory made it from serial nr
muccaz
PostPosted: Fri Jan 04, 2008 11:50 am    Post subject: how do you tell witch factory made it from serial nr Reply with quote
hi
can anyone tell me and easy way to tell wher a guitar was made ,,witch factory ....... i got a greco with 2 52xx and another with a8152xx both les poul custom
i think 2 52xx is kaneda... and a 8152xx is fujigen ,,,,,,
but can you help me
otto
Ozeshin
PostPosted: Fri Jan 04, 2008 5:08 pm    Post subject: Reply with quote
Do a search at the Matsomoku forums:
http://www.matsumoku.org/ggboard/index.php
PostPosted: Fri Jan 04, 2008 6:23 pm    Post subject: Reply with quote
Hi Muccaz, that was more than likely made by Dyna Gakki. I'm pretty sure they were only made in the 2 factories {MIJ} Fujigen Gakki and Dyna Gakki.
Cheers Mick
muccaz
PostPosted: Fri Jan 04, 2008 7:34 pm    Post subject: Reply with quote
Cheers Mick
hi mick
thanks but is the 2 52xx number dyna gakki then ,,,, i think a8152xx is fujigen ,,,, right '
otto
PostPosted: Fri Jan 04, 2008 8:19 pm    Post subject: Reply with quote
You got it...
muccaz
PostPosted: Fri Jan 04, 2008 8:28 pm    Post subject: Reply with quote
You got it...
hi again
but witch one is the best ...... factory
otto
PostPosted: Fri Jan 04, 2008 8:35 pm    Post subject: Reply with quote
I can't honestly comment on Dyna because i've never owned one of theirs, the one i own is a RR 65 fujigen model with the dry 1982 pups and i love it, so if i was buying another one i would buy another early eighties fujigen model. But in saying that i have read a lot of great comments on the Dyna built guitars as well, personally i think the guitars from Greco were better in the early eighties than the later ones although there is always an exception to the rule, remember this is my opinion only and i'm sure someone else will chime in with some more info....
japanstrat
PostPosted: Sat Jan 05, 2008 1:22 am    Post subject: Reply with quote
Revised.
The Grecos in the 1960s were made by Teisco and Fujigen.
The Grecos in the 1970s are made by Matsumoku and FujiGen with Matsumoku seeming to make only certain models like some Greco Fender copy models and a bolt on SG model. Greco serial numbers start around 1975. There are also Greco LP's from around 1977 with a sticker serial number in a MYYXXXX format and also Guild like headstock Greco LP's from around 1979. Then for the Super Reals in the early 1980s and the Mint Collection up till the early 1990s the serial numbered Grecos seem to made by just Fujigen judging by the body routing and wiring channels etc and have MYYXXXX and YXXXX (MYXXXX) serial number formats. No one really knows why Fujigen is using 2 serial number formats on the Grecos, maybe it's a distribution thing. Fujigen were using the MYYXXXX format only on Ibanez's up till 1987. The MYYXXXX format is the same as the Ibanez format and starts around 1975 and goes to the early 1990s. The YXXXX format starts around 1979 and goes to the early 1990s. Also in the late 1980s the Cor-Tek (Cort) made low end no serial Grecos (like EG-600 and lower) appear and also the Tokai made no serial Grecos with fret edge binding (EGC-75) appear probably because in the late 1980s Fujigen was reducing set neck guitar production. The Grecos with a bolt neck tenon from the late 1980s/early 1990s seem to also be from Fujigen and I suppose Fujigen were doing the low end Grecos this way because it's easier to do set necks this way and at the time Fujigen wasn't that interested in doing standard set necks because of the time it takes to get the action and angle right for set necks so they did a quicker to set up bolt on set neck joint on the low end Grecos. I think the Greco Dyna connection came after the early 1990s.
The Greco pickups from the 1970s and early 1980s like the U-1000 pickups were made by Nisshin Onpa (Maxon) and then around 1981/1982 the Greco pickups get a makeover and have different names like Screamin etc. In 1981 Fujigen started making their own pickups so maybe that's why the Greco pickups change.
muccaz
PostPosted: Sat Jan 05, 2008 4:42 am    Post subject: Reply with quote
japanstrat wrote:
Yes the Dyna Gakki 2 52xx serial and the FujiGen a8152xx serial Grecos are about the same in terms of quality.
FujiGen had been making Grecos and Ibanez's from the early 70s and Dyna started making Grecos around 1978/1979.
The Dyna serials are mostly on the lower end Grecos around the late 70s/early 80s like the Super Powers but the Dyna serials were also on some of the high end Grecos as well.
In the late 80s the Dyna serials are on most of the Grecos because FujiGen wasn't making many Greco LP's in the late 80s because they couldn't be bothered with set neck guitar making.
Most people know FujiGen but not Dyna because FujiGen made a lot of Ibanez guitars and the early Fender Japan guitars.
hi
the one with 2 52xx is a 3 piece top and 3 piece back.. flower pot logo .... but i think the hard ware has been changed is is not gold ....but crome hard ware ,,,,, but it has fret bindings and dry 1982 pickup ......... 50 style neck .... not easy to id an old greco ,,,,,,,,,
a good guitar ,,,,,,,, anyway
PostPosted: Sat Jan 05, 2008 4:59 am    Post subject: Reply with quote
Are you sure it has a 3 piece back??. The models with dry 1982 pups have 2 piece top and backs, although i have seen one with a 3 piece top. And by the way those dry 1982 pups are very good..
muccaz
PostPosted: Sat Jan 05, 2008 5:18 am    Post subject: Reply with quote
hi mick
yes it i am sure ......but good sound from dry 1982 ... very easy to see it is 3 piece back it is 30/10/60
it is black a custom but i ?think all custom have gold hardware ,,, but this one have nickel or crome hardware ...... not easy to id
i got 30 guitars now all mij from the early 80
greco burny washburn fender jv squer sq ibanez yamaha an old kramer usa witch i think is an esp with made in usa on it
PostPosted: Sat Jan 05, 2008 5:22 am    Post subject: Reply with quote
Its possible it is made up of different parts but as long as you like it thats all that counts...
muccaz
PostPosted: Sat Jan 05, 2008 5:51 am    Post subject: Reply with quote
hi mick
did they make guitars from left over parts ..... or do you think it has been changed
otto
PostPosted: Sat Jan 05, 2008 5:57 am    Post subject: Reply with quote
I meant someone had changed parts on it....
muccaz
PostPosted: Sat Jan 05, 2008 6:03 am    Post subject: Reply with quote
yes i think that too ...... but funny to change the hardware to nickel and the pickups to dry 1982 ,,,,,,,,,
when i got it .... i was thinking a highend guitar ,,,,,, becourse off the pick ups ,,,, but with a 3 picece body and top ?????...... i dont think so any more but but it has got fret bindings ,,,, otto
