and tonal complexity compared to their other Les Pauls or MIJ clone? After having put my recently acquired 130 LTS through it's paces, compared to my Tokai LS200, it's a bit lean on the low end. The tone is more airy and light and not as authoritative as the Tokai. I've swapped the same set of pickups between the two guitars and found the same comparison. I wonder if it just has to do with the fact that the Edwards is a good 1-2 pounds lighter than the Tokai? I also had a 80s Burny that I sold after getting the Edwards, and the Burny also had better low end response and that Les Paul growl and grunt. It was even heavier than the Tokai though. Any thoughts?
