GRECO PU 2 pickups - any good?
MIJvintage
PostPosted: Mon Sep 10, 2007 8:23 pm    Post subject: GRECO PU 2 pickups - any good? Reply with quote
I recently acquired a 1980 Greco EGF-850, the pickup bases are stamped (embossed) PU 2, and also ink stamped with an upper case A, and 200220
I've heard of these/read about them but haven't owned any, until now
Does anyone here know if the Greco PU 2 pups are any good?
Thanks in advance for any info
As a side note; the rear pup is a double white & the neck pup has at least one white bobbin (seen through hole in photo).......
MIJvintage
PostPosted: Wed Sep 12, 2007 4:16 pm    Post subject: Reply with quote
Thanks for all those replies & keep 'em coming, lol.....................
.........I put new strings on this beat up girl, adjusted the bridge & the truss rod each, a couple of times, and I must say, I am very impressed with the output & response of these PU 2 pups but then again, taste in pickups is a very subjective issue.............
I actually believe these PU 2s are closer in response to the older Burny VH-1 pups; I like these much better than the pups in most of the other Grecos I have owned
japanstrat
PostPosted: Thu Sep 13, 2007 12:17 am    Post subject: Reply with quote
The 1980 prices of Greco pickups were
Dry 20,000 Yen
PU-2 15,000 Yen
U-2000 12,000 Yen
U-1000 10,000 Yen
EGF1800 DRYx2
EGF1200 DRYx2
EGF1000 PAFx2
EG1000C DRYx2
EG900 PAFx2
EGF850 PU-2x2
EG800GS HOT LICKx2
EG800C PU-2x2
EG800PB U-2000x2
EG800PR U-2000x2
EG800 PU-2x2
EG700 U-2000x2
EG600PB U-1000x2
EG600PR U-1000x2
EG500 U-1000x2
EG500C UDx2
EF500J U-1000x2
EG500GS UD-DXx2
EG480 UDx2
EG450 UDx2
MIJvintage
PostPosted: Thu Sep 13, 2007 4:27 am    Post subject: Reply with quote
japanstrat, thanks for the info, very nice
in the listing, the seller claimed the pups as Double Trick so, I suppose the seller didn't even bother to remove 4 screws to actually determine what the pickups really were
just another example of another seller passing off something, that was really not what the seller claimed, and in this case it was an easily identifiable item
funny how some sellers wanna piss & moan when their snafus are thrown about...........................
MIJvintage
PostPosted: Thu May 20, 2010 2:15 pm    Post subject: Reply with quote
finally got around to pulling the covers on these 1980 Greco PU-2 pups, and as suspected, they are 100% double white
I think I will put them in the 'shop order' BLS-59 after it arrives in a couple weeks ..............
magnets are not at all charcoal in color but are very silver = Alnico , also as suspected ......................
dombat
PostPosted: Fri May 21, 2010 7:13 am    Post subject: Reply with quote
Which Greco pu are comparable to the '80 Ibanez Super 70, manufactured by Maxon too?
japanstrat
PostPosted: Fri May 21, 2010 7:20 am    Post subject: Reply with quote
U-1000
dombat
PostPosted: Sat May 22, 2010 7:12 am    Post subject: Reply with quote
japanstrat wrote:
U-1000
Are you sure that the U-1000 has alnico 8 magnets?
ozgrecofanatic
PostPosted: Sun May 23, 2010 2:34 am    Post subject: PU-2 Pickups Reply with quote
Well here's the deal. Last night I played my just recently acquired 1980 EGF-850 at a gig. The guitar looks great, feels great etc BUT the PU-2 pickups left me COLD.
I realise that this is a bit of sacrelige but the U1000 pickups in my EG-500 Super Real sound better. More "sparkling" and probably a bit more higher output. I confess to being a bit disappointed.
Anyone here know the output of these 2 sets?
Dave
Juni41
PostPosted: Sun May 23, 2010 2:58 am    Post subject: Reply with quote
I don't know the output level but I have played a lot with PU-2 in my EGF850 and they were really great pickups.
No so far from the Dry Z in fact...
Not as great off course but near.
That's why I very surprise of your post.
MIJvintage
PostPosted: Sun May 23, 2010 8:58 am    Post subject: Re: PU-2 Pickups Reply with quote
Dave
Maybe your PU-2s would sound better to your ears, in a different guitar?
Just a thought.
Too bad you don't like them in the 850
I have played the same set of pickups, and in different guitars, and they can sound quite different in the different guitars.
I have done this with many sets of pickups.
It would seem reasonable to assume that a set of pickups would sound the same, or almost the same in any guitar but from my expereince, that is not the case.
The above pictured PU-2s sounded great in the 1980 EGF-850 that they were originally in, even though the guitar was a POS with the delaminating veneer top
I have yet to install the PU-2s into a diffrent guitar but when I finally do get around to it, I hope they sound as good as they did in the EGF-850.
If they do not, I won't be surprised.
muccax
PostPosted: Sun May 23, 2010 10:28 am    Post subject: Reply with quote
hi
if you dont like them ........ i would like to try them
and i am pretty sure you dont like them
all the best
otto
MIJvintage
PostPosted: Sun May 23, 2010 11:46 am    Post subject: Reply with quote
muccax wrote:
hi
all the best
otto
LOL true dat ........
what he said ...................
japanstrat
PostPosted: Mon May 24, 2010 2:14 am    Post subject: Reply with quote
Yes, I'm pretty sure.
I have some U-1000 pickups and I've also had Super 70s and they are just about the same.
The Alnico 8 magnet produces a distinctive brightish sound in the old Maxon pickups plus Maxon have said they used Alnico 3, 5 and 8 in the old pickups and Dry Z are Alnico 3 and therefore sound vintage like and U-1000 have the Alnico 8 thing going on and are bright and chirpy and verging on ceramic in lots of ways but still have Alnico characteristics and U-2000 have the Alnico 5 thing going on, standard sort of thing and not as bright as Alnico 8.
ozgrecofanatic
PostPosted: Mon May 24, 2010 2:33 am    Post subject: PU-2 Pickups Reply with quote
Japanstrat that's exactly what I hear! My U-1000 pups are bright and airy and probably a little higher in output. The PU-2 are much "middier" to my ears. Also the neck pup on this guitar is WAY louder than the bridge. I even ajusted the bridge up as far as possible but it's still a lot weaker than the neck....Gonna keep tweaking and see how I go.
Dave
