Details
felixcatus said:
Ground plate with 'soft in between' switch are nice standard feature details to me.
Really cool to see a grounding plate that is so clean with no components on it. I am in the process of completely rewiring a Springy that someone screwed up the wiring on. Love the lugs/loops they provided to solder too. Very cool.
some details of my VSB80 translucent laquer finish all over. Knobs and bridge are not original.
● Policy 5
Tone selector switch Old Strat is nonsense if there is no half tone !! Therefore, domestically produced Pee developed a 5 step switch. A new design that uses a 3-stage 5-position switch, which does not have a rugged garden like the 5-stage, and at the same time has a smooth operation and a half-ho position.
(diagram of selector)
★ 3-stage 5-position switch
★ Position is decided as "Smooth 2"
● Policy 6
This part is not directly visible, but we are looking for the first Shinroku shield plate made in Japan, so we will use the shield that has been written for a long time. When wiring, a separate terminal is provided and soldered so as not to deteriorate the performance of the barrier pull register. Maintenance is also easy. The guitar needs a wiring shield that is so elaborate.
(diagram with grounding plate)
★ ST Shi-2
★ This is the first domestically produced shield freight made by Shinkan.
(diagram without grounding plate)
★ Lee and others
★ P Lumi has no durability
http://www.tokaiforum.com/viewtopic.php?f=11&t=26211
*Not the best translation, but gives you an idea of what they were saying. 8)
Image of pristine new wiring for a Springy from the 1979 catalog.
(Jack and trem claw not wired)
The first domestically produced brass shield plate. Stable shielding effect for a long time Demonstrate. When wiring, variable To prevent the performance of the sister (variable resistor) from deteriorating due to heat during soldering work. A separate terminal is provided for the ST series and soldered to it. Therefore, maintenance The tone selector switch is a 3-stage switch. Adopted. Of course, '54 Strat halftone Is extremely easy to issue. The setting can be set quickly, and it will not fall out during the performance. (newly developed, 3 steps, 5 positions switch.
