1980s 1984 "Tokai With Super Bending Machine" SVS65 Ad
TOKAl with SUPER BENDING MACHINE
Tokai did a great job.
Super Bending Machine SHIFT2001 Mount
SD-65 limited release which was delivered with confidence to musicians all over the world.
The power of the SHIFT2001, which surpasses all other vibrato units on earth, will not only revolutionize the contemporary music scene, but will also bring about a timeless monster sound. Thank you for breaking through the times.
SHIFT2001 Amazing Mechanism
•SHIFT2001 can independently adjust the vibrato (bend change amount) while maintaining harmony. Uses torsion bar springs. Different long sustain and rebound by heat hardened stainless steel roller and roller can be used. The adjustment screws are laid out in an engineering position between the fine tuners to achieve a smooth and wide effect in a short time.
• Uses miniature bearings. Adjustable arm angle For arm lock brake SHIFT2001 was used. As a result, partial resonance disappears, and the original characteristics of the body material are fully utilized. Clear sound from low range to high range.
SVS-65 • ¥65,000
•Monster G sound, SHIFT2001 mount
•Limited edition of 50 pieces
•Scheduled to be released on October 20, 1984
SPECIFICATIONS
Body sen
Alder neck
U shape Fingerboard
22 frets
400R Rose fingerboard
Frets: Wide frets
PU:bar type
PU control volume
Tuning pegs: Mini rotomatic type pegs
Vibrato unit: SHIFT2001
SHIFT2001 Lock nut equipped
Non-pick guard panel
Colors: APWR (all pearl white) ABR (all black). AMRR (all metallic red), APPR (All Pearl Pink)
check bost
