I just know that there are long switches which gibsons use and there are also short switches which are typically used on imports. I read somewhere on here that some tokais use a short shaft with long threading but I’m not sure if that prewired kit I linked would work. My switch currently works, but whoever owned the guitar before me did some weird wiring so I want to convert it back to 50s style braided wiringWhat do you mean by fit? Fit the opening in the body? If so, I'm not sure.
Is your switch not working? If so, you might try contact cleaner before you replace it.
yeah someone before me had already enlarged the holes to fit normal CTS pots so luckily I won’t have to do anything to swap in my VIPotsCTS makes a metric pot. Mine didn’t last very long before going scratchy. Also didn’t like the taper. VIPots clean up very quickly from 10 down to 7/8, then the taper is more gradual as you head down to zero like a vintage pot.
Also beware of pots that claim “vintage taper”. Most of these are a 30% taper, not the 10% of VIPots and vintage Centralab.
Yeah I have a pair of Rewinds laying around that I’m going to put in there and I am going to redo the wiring with VIPots and NOS black beauty’s. I am hoping that has the biggest impact on tone. Whatever pickups are in the guitar right now are just too hot for my taste and get muddyI did the 'Faber thing' to my LS150F just last week - brass bridge posts and thumbwheels, ABR-1-a-like bridge, steel tailpiece studs and inserts.
The 4mm brass posts screw right in with no mods necessary.
The tailpiece inserts are a half mm larger diameter than the (Gotoh) ones Tokai fitted, so I had to ream the holes out for them to fit.
How does it sound? Not dramatically different. It is different, but if you're expecting the clouds to part and a beam of light, forget it.
Regarding the bridge, I would have gone with the Four Uncles one (the only one I know of made from the same material as the '50s ones), but my anorak pockets are not that deep.
The Faber parts are stunning quality, by the way.
What other mods has the guitar had?
A couple of years back... correction, three years back - how time flies... I fitted Amber Spirit Of '59 pickups with Bareknuckles 550k/10% pots and their PIO (more money than sense) caps.
All that did make a dramatic difference. If 'vintage PAFs' are your thing, these are in a different league to what Tokai fitted - for what they cost, they should be. "Other 'PAF' obsessed winders are available" as they say. Wizz, Throbak, Rewind... etc. They're all superb and they're as varied as the original PAFs are. It's important to realise, when it comes to PAFs, that there is no 'one PAF sound'. Who's pickups you should buy depends on who's sound is the one you want to be near to.
I've never tried Rewind pickups, but I've read the book he helped write about PAFs.Yeah I have a pair of Rewinds laying around that I’m going to put in there and I am going to redo the wiring with VIPots and NOS black beauty’s. I am hoping that has the biggest impact on tone. Whatever pickups are in the guitar right now are just too hot for my taste and get muddy
