Is It a ST60 or a ST80?
MIJvintage
PostPosted: Sun Mar 16, 2008 8:53 am    Post subject: Reply with quote
Peter Mac wrote:
this guitar is an ST-50 YSOR. It's the 'U' that gives it away, in that Goldstar sounds had different pickup letters for ST-50's and ST-60's - Springysounds did not.
It has an obvious Alder body, 1963 radius fingerboard and square string tree, but on an ST-60 Goldstar, the pickups are stamped "V'.
regards
Peter mac
I know that the ST-80 has the 2 piece center seam body but does the ST-60 also have this same feature?
I am curious to know why so many ST-50 models have 3 piece bodies, while I have seen just a small hand full have the center seam 2 piece, such as the example I have?
Is it possible that Tokai used the 2 piece center seam bodies from the higher spec ST-60 & ST-80 models, for just a very few examples of the ST-50, by mistake?
PostPosted: Sun Mar 16, 2008 9:52 am    Post subject: Reply with quote
We have seen there are some exceptions to the rule in Tokais and a "lower" model sometimes have higher specs than it should according catalogs but it?s not ususal. Mike(javelin70) stated he got a LS-50 Love Rock over other guitars because it was a really good guitar.
Just trust what Peter says, he has seen(inspected) so many Tokais and not Tokais old guitars to be knowledge enough....
Saying that, I was lucky to try a '78 Reborn LS-60(but different branded),a 1979 Les Paul Reborn LS-80 and a 1981 Love Rock LS-50.Each was different and LS-80 was the best of the 3,being LS-60 second best.LS-50 whereas good,lacked bottom end(because multipiece back and top).....But I feel 2003 LS-320 better and my main prefference when choosing Tokai.
MIJvintage
PostPosted: Sun Mar 16, 2008 10:56 am    Post subject: Reply with quote
luis, peter makes some valid points, although I'm not real sure about the pissing contests, losing value, & the Harleys..............
What I am interested in the most is the fact that nearly all of the sunburst Goldstars I see that have the U stamped pickups, 9 of 10 or even more, have at least a 3 piece body
So, I go back to my observation; why so many U stamped pickup equipped Goldstars with 3 or more piece bodies, and conversely, why so few of the very same U stamped pickup equipped Goldstars with a 2 piece center seam body?
I am only looking for input from those with the knowledge; looking for valid theories here..........not frivilous comments..............
ochay
PostPosted: Sun Mar 16, 2008 12:09 pm    Post subject: Reply with quote
I have 15 of the goldstars hangin on the wall right now- I'm gonna check um and post what I find-
Guitar Farmer !
MIJvintage
PostPosted: Sun Mar 16, 2008 12:17 pm    Post subject: Reply with quote
cheshirecatsmile
PostPosted: Sun Mar 16, 2008 6:47 pm    Post subject: Reply with quote
There have been a couple of higher end Goldstars on ebay recently to compare this one to. I didn't catch this one in time (muttered curses....):
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=230229538654&ssPageName=ADME:B:ONA:GB:1123
If it does actually have a V-neck it's probably a TST-80--duosonic from the forum won this, so if he's reading maybe he can tell us about it!
and then there was John's from the forum:
http://cgi.ebay.com/Tokai-Goldstar-TST80-Strat-like-springy-sound_W0QQitemZ120222925784QQihZ002QQcategoryZ112670QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
with U pickups, a V-neck and nitro finish--there was a whole other post on this one:
http://www.tokaiforum.com/viewtopic.php?t=10167
I have a similar Goldstar that I believe is a TST-50 (no sticker)-- GS nitro finish, U-neck and U-stamped pickups. Body is alder, and maple neck. I don't have any photos of mine, but I'll take some and post them soon. It's truly an amazing guitar and as good or better than my higher end Springys.
There was a Springy model listed in the Japan Vintage magazine (page 15 on the right side)
http://s215.photobucket.com/albums/cc152/gothamcitydrugstore/Japan%20Vintage%20vol2%20Springy%20Sound/
that has an ST-80 model body with a U neck--I wonder if this is a similar phenomenon....?
________
VAPORIZER
Last edited by cheshirecatsmile on Sun Feb 13, 2011 11:58 pm; edited 1 time in total
MIJvintage
PostPosted: Sun Mar 16, 2008 7:30 pm    Post subject: Reply with quote
cheshirecat, the one chingo had listed looks like a 2 piece center seam body & it has E stamped pups BUT it has a pot metal/zinc block
John A's listing states center seam body, has U stamped pups, but is listed as a ST-80
My Goldy has the 2 piece/center seam body, U stamped pups, and a steel block w/Final Prospect saddles
the similarities are not exact, just similar .....................
I am thinking that my Goldy has a ST-60 or higher spec body but definitely has the U stamped pups, previously stated here as belonging to the ST-50
duosonic
PostPosted: Mon Mar 17, 2008 12:20 am    Post subject: Reply with quote
chingo's guitar was parted together: a 1980 ST80 body, and a later ST50 Goldstar neck...
cheshirecatsmile
PostPosted: Mon Mar 17, 2008 2:39 pm    Post subject: Reply with quote
Hey MIJ,
Does your Goldstar have a nitrocellulose, or polyurathane finish? And duosonic--are you sure that your guitar is parted together? I'm almost certain my Goldstar has a nitro finish, with an incredibly well matched 2 piece body (alder, mind you), but it's got a U shaped neck. Mine looks untampered with. I'm wondering if these 1954 and '58 "vintage models" all had nitro finish?
________
Buy Air One Vaporizer
MIJvintage
PostPosted: Mon Mar 17, 2008 3:37 pm    Post subject: Reply with quote
cheshirecatsmile wrote:
Hey MIJ,
I seriously doubt mine is nitro; pretty sure it's poly..........and of course mine is a '64 copy.............
duosonic
PostPosted: Mon Mar 17, 2008 4:31 pm    Post subject: Reply with quote
Yeah, I'm positive the chingo Goldie was a parts job... not that I'm complaining! It's a poly TST-50 Goldstar neck, and the body is definitely nitro and did not come with that neck. The neckplate, however, footprints correctly, and it's from 1980, so...
bluejeannot
PostPosted: Fri Feb 26, 2010 8:07 pm    Post subject: Reply with quote
Peter Mac wrote:
regards
Peter mac
Hi Pete , I just stumbled across this whilst looking for something else.In my somewhat limited experience admittedly, the three GoldstarST 60sI have come across (2 of them owned by me)have had E pickups not V`s.Regards Gabe.
bluejeannot
PostPosted: Sun Feb 28, 2010 8:47 pm    Post subject: Reply with quote
Hi Gabe,
'E' pickups would more likely make it a TST-70 or TST-80. To me the body being alder and not a spectacular grain would point toward the TST-70 (although most TST-70 had 60 slab board and not 64 thin)
TST-80 did tend to use Ash bodies with maple necks and high-grade Alder with rosewood neck.
regards
PostPosted: Mon Mar 01, 2010 5:53 am    Post subject: Reply with quote
Peter.
How come there is no mention of the ST70 in the most commonly available catalogue in the UK, 1985 Vol 1?
Since the only ST70 I can recall seeing on here is owned by a well known long haired Australian rocker (Hi Mick ), was the ST70 something for the antipodean market?
Also, I have to agree with Gabe. From what I have seen on here, ST60s seem most likely to come with Es, though some have Us. In many cases, the only difference between an ST60 & an ST80 is that the 80 has a V neck & nitro finish.
PostPosted: Mon Mar 01, 2010 5:58 am    Post subject: Reply with quote
I had a black/maple ST60, 60 sticker on the neck, practically mint, and I would looked totaly original, it had E pickups too
Page 2 of 3
