Normal STP vs Wrap-around STP
togps
PostPosted: Sun Nov 12, 2006 6:13 am    Post subject: Reply with quote
Euro 24
Shipping Euro 3 (within Europe + UK)
Shipping Euro 4 (Rest of world)
Paladin2019
pm sent
www.tokaiguitar.de
Alpedra
PostPosted: Sun Nov 12, 2006 7:38 am    Post subject: Reply with quote
Tried the wrapparound for a few months.. and didn?t notice any significant difference in the sound... sustain is about the same, it seems.. just the strings felt much more easier to bend... which is a plus... but.. went back to the usual wrapping.. actually the tailpiece?s back and top was beginning to suffer from the wraparound.. so.. I think I will keep the strings the usual way from now on.
Paladin2019
PostPosted: Sun Nov 12, 2006 12:45 pm    Post subject: Reply with quote
Yes, I noticed that too after only a few days with the top wrap. The strings cut into the bottom of the TP quite badly and made some light marks on the top.
togps - PM replied
TUNAFREAK
PostPosted: Tue Nov 14, 2006 10:27 am    Post subject: Reply with quote
I have tone pros tp posts that tighten down and really help sustain. I have tail wrapped for a long time and I do it to all of my guitars. If you worry about the tail piece damage , you can allways replace it at a latter date. It makes a big diff in the way a guitar looks and feels, I've never had a problem with string breakage. I love it!
Mark
tudor
PostPosted: Wed Nov 15, 2006 11:48 am    Post subject: Reply with quote
I've got the Faber kit today from togps - a review follows as soon as possible ...
Roger
Paladin2019
PostPosted: Wed Nov 15, 2006 11:54 am    Post subject: Reply with quote
Roger
I have one on the way... can't wait to try it!
tudor
PostPosted: Wed Nov 15, 2006 11:57 am    Post subject: Reply with quote
OK - let's do the job together ...
... what I perhaps will forget to mention - it's your turn to add or to correct - OK ???
Roger
Paladin2019
PostPosted: Wed Nov 15, 2006 12:01 pm    Post subject: Reply with quote
Roger
Agreed
Mine will probably take a while to get across the continent though.
Paladin2019
PostPosted: Fri Nov 17, 2006 11:36 am    Post subject: Reply with quote
Woohoo! Got my kit in the post today. Will install it over the weekend and make my report.
tudor
PostPosted: Fri Nov 17, 2006 2:12 pm    Post subject: Reply with quote
... so will I !!
Roger
tudor
PostPosted: Sun Nov 19, 2006 3:05 pm    Post subject: Reply with quote
... as promised - here my review:
Mounted a Faber Kit today ? brought it with me from a visit to togps .
The reason for replacing was, that I wanted to keep the stock Alu STP of my ?85 LS150 free from damage and scratches by the strings in the wrap-around mod.
But ? what a surprise ? it was the best solution I could get !!
Not alone that I had a nice new, but ?aged? STP ? in addition to that togps provides also 3 different spacer rings in alu for improving the height adjustment of the studs without having a lack of tone.
I chose the middle high one to get a comfortable hight and tension for the strings.
The mounting was so easy because the STP doesn?t slip from the studs any more because it will be held by turning the studs with the put on spacer rings into the threaded bolts in the body ? so the STP is tightened and the restringing is so easy - now your 10 fingers are enough to get it in opposite to former efforts ? and - the most important advantage ? no dings or dongs on the finish caused by a loose and falling STP ?
The STP is absolutely tight ? no vertical tipping of the STP by the tension of the strings, as it happened with the normal STP. The spacer rings are keeping it in a horizontal level.
Let?s talk about the sound ?
The spacer rings have an additional positive effect on tone and sustain ? they are a better connection to the body than the studs alone being turned out wide enough to optimize tuning and intonation. The sustain is increasing and there is a better attack and ? you feel the vibrations on your body again. If you don?t feel it - I can?t help you !!
[img][/img]
[img][/img]
[img][/img]
Roger
Paladin2019
PostPosted: Sun Nov 19, 2006 5:58 pm    Post subject: Reply with quote
I'll post a detailed review tomorrow, but for now I'll just say that I'm *very* impressed with the faber kit - I already had a gotoh alu tp and tonepros locking studs on my love rock, but the kit works even better.
Paladin2019
PostPosted: Mon Nov 20, 2006 3:17 am    Post subject: Reply with quote
Following on from tudor's review, here are my impressions of the faber kit.
I've seen two similar methods used to improve body coupling over the years. The first was tonepros locking studs, but these still poke out from the body unless you top wrap. Secondly, I've seen people on the LPF make alu spacer rings to use with standard studs, a technique that improves body coupling but doesn't lock the tailpiece. The faber kit is the best of both worlds, improving coupling and locking down the tailpiece without the need for top-wrapping or otherwise altering your setup.
My guitar already had an alu stp and tonepros studs but I decided to try the faber kit because it was remarkably cheap (27 euros to the UK inc postage) and because the rings come in alu, which is always good to have in bridge hardware. The kit comes with three spacer sets at different heights - the tallest one was closest to the height I was using, so I installed that. I used the same set of strings before and after to make sure that the comparison was fair.
The result? Well, to be honest I wasn't expecing a big difference because I already had locking hardware. I was wrong, there was a *very* noticeable improvement. Better sustain, more volume, a depth and 'tightness' to the notes that wasn't there before, and you really can feel the body resonate more!
This is the only locking hardware you can buy that clamps the whole stp layout solidly in place - like Gottfried says, the entire thing becomes a massive sustain block. Not only that, but because you don't have to do the top wrap you can keep a hard break angle on your strings, which improves vibration transfer. The results are excellent.
Disadvantages? Well, the obvious one is the limited adjustability. There are only three spacer sets (2.5mm for top wrapping, 4mm and 5.5mm - it's a well-chosen range). However, unless you're VERY picky about your setup or have you tailpiece set unusually high you should be able to pick a set that is so close to your current setup that it makes no noticeable difference. Even if you are the picky type, the improvement in tone is worth the loss of adjustability. Anyone who's played a '54 les paul or a 3-saddle tele will know what I mean.
The faber kit really works and is much cheaper than other types of locking hardware out there. A fantstic buy. Well done Gottfried!
PostPosted: Mon Nov 20, 2006 6:57 am    Post subject: Reply with quote
I remember i have pending to install the ones I got in my guitars I will do it very soon when I have some free time to sit down a while and taste it as I take some time to myself to experiment.....I guess Gottfried will have to lauch some Faber kits in gold soo because our request,mine too....
hawkeye2u
PostPosted: Fri Dec 08, 2006 3:13 am    Post subject: Reply with quote
I also got the Faber kit & the ALU STP (polished)
Installed it the other night
Havn't had a chance to gig with it yet, this sat & sun I will, but my first impressions are as follows
I do the Wraparound with the smallest rings in the kit, slowly nipped the studs up until they stopped, then 1/32 more turn to tightned them up, solid as!!
I've found that the tone has improved,clearer, sustain is longer, attack is the most noticable difference, mind you , I'm only at garage levels to unplugged levels, I'll give a more in depth rev after sun night gig
So far very impressed
Fast shipment & a good communicator our Gottfried, although we had some language barriers , My Fault, LOL
Page 2 of 3
