Will this Push Pull fit a LC ?
Web Surf
PostPosted: Thu Aug 24, 2006 10:29 am    Post subject: Will this Push Pull fit a LC ? Reply with quote
Will these fit into a Tokai LC ?
http://www.thomann.de/thoiw2_artikel-183519.html
G?ldo
Push/Pull Poti 500Kohm
G?ldo Push/Pull Poti 500Kohm Push/Pull Poti, 500 KohmA-log., small size, 8mm? , 10mm long
Paladin2019
PostPosted: Thu Aug 24, 2006 10:36 am    Post subject: Reply with quote
Yes.
Web Surf
PostPosted: Thu Aug 24, 2006 11:17 am    Post subject: Reply with quote
And is "Log A" what I am loking for ?
Paladin2019
PostPosted: Thu Aug 24, 2006 1:45 pm    Post subject: Reply with quote
Yes - "audio" or "log" taper pots are best for the guitar's volume and tone controls.
Most guitars use a linear taper as standard for the tone controls, but log taper is much more useable.
If you're in the UK, you should be buying from:
http://www.allparts.uk.com/
They have the pots you need in stock.
Web Surf
PostPosted: Mon Aug 28, 2006 10:52 am    Post subject: Reply with quote
Thanks,
So now I understand that 500 KohmA-log., small size, 8mm? , 10mm long shaft pots are OK for Tokai's without any widening of holes.
Now for the Humbucker Pickups with gold cover, I understand
A) I need "Gibson" spacing pickups and not "Fender" dimensions.
B) Neck pickups have closer screw positions 1 14/16th inch while Bridge pickups have screw distance of 2 inches.
C) Almost any "Gibson" type HB Pickup will fit my Tokai LC ie there are standards for hole spacing etc.
Paladin2019
PostPosted: Mon Aug 28, 2006 3:14 pm    Post subject: Reply with quote
Web Surf wrote:
Thanks,
Or, in standard guitar lingo, 500k short shaft audio taper pots.
A) I need "Gibson" spacing pickups and not "Fender" dimensions..
Yes. However, gibson spacing is standard. The other kind will always be marked "F" spacing.
Web Surf wrote:
B) Neck pickups have closer screw positions 1 14/16th inch while Bridge pickups have screw distance of 2 inches..
No idea. It won't matter anyway, neck and bridge pickups will always be marked as such.
Yes.
