Truss rod cover
Goto page 1, 2, 3, 4  Next
Deadman
PostPosted: Tue Mar 07, 2006 11:45 am    Post subject: Truss rod cover Reply with quote
Just a quick question guys:
Will a G***on LP Standard truss rod cover fit a Tokai LR?
Cheers.
ganzua
PostPosted: Tue Mar 07, 2006 11:50 am    Post subject: Reply with quote
http://www.tokaiforum.com/viewtopic.php?t=5327&highlight=
Quote:
Gibson truss rod covers won't fit modern tokais unless you fill and re-drill one of the holes.
Snake
PostPosted: Tue Mar 07, 2006 12:48 pm    Post subject: Reply with quote
I was thinking about this recently. I thought about shaping my own truss rod cover. I'm in the process of making a custom pick guard for a strat style guitar, although it will have to be more fiddley than that, has to be worth a try..?
Deadman
PostPosted: Tue Mar 07, 2006 1:55 pm    Post subject: Reply with quote
Interesting, Snake. Good luck with it.
Oh and thanks Ganzua, don't fancy drilling holes in my prospective LS150 though!!!
Rigid Digit
PostPosted: Thu Mar 09, 2006 7:49 am    Post subject: Reply with quote
Yes, it will fit on a Japanese two screw one. I put a genuine Gibson bell shaped one on my Love Rock Junior.
hammer4ever
PostPosted: Thu Mar 09, 2006 12:56 pm    Post subject: Reply with quote
yep! just put a Gibson TRC on my LS120............... Perfect fit............... and looks.
For those about to ROCK!!!!
ganzua
PostPosted: Thu Mar 09, 2006 2:02 pm    Post subject: Reply with quote
So, do they fit ok? Did you have problems with the metric screws?
Paladin2019
PostPosted: Thu Mar 09, 2006 3:57 pm    Post subject: Reply with quote
Why would you have problems? You'd just re-use the orignial ones.
It seems Tokai have changed their TRC dimensions recently because the bell didn't fit my '01 love rock. Had to have one made for me.
hammer4ever
PostPosted: Thu Mar 09, 2006 4:08 pm    Post subject: Reply with quote
As Paladin says' just use the original screws.......... and to be honest' they look a lot better than the gibson one's supplied! (smaller)
But yeah' the holes line up exactly.
ganzua
PostPosted: Thu Mar 09, 2006 4:25 pm    Post subject: Reply with quote
Ooopps!!!! You are right!
I'm thinking in getting a metallic chromed trussrod cover for my future Tokai.
Snake
PostPosted: Fri Mar 10, 2006 11:12 am    Post subject: Reply with quote
That's great if you can fit Gibson truss rod covers to modern Tokais, I read that the vintage ones where the same height, but at some point they changed it.. According to someone on ebay selling Les Paul TRCs, a Gibson cover is 6 cm from end to end, and 5.2 cm from hole to hole. I'll have to check the hole to hole dimentions of my tokai when I get home, but if anyone has the information to hand that'd be cools.
Deadman
PostPosted: Fri Mar 10, 2006 11:41 am    Post subject: Reply with quote
I missed out on a 'Standard' cover off ebay for ?5!!
Dammit!
PostPosted: Fri Mar 10, 2006 12:02 pm    Post subject: Reply with quote
I've used Rockinger bell style trussrod cover sucessfully,just have to climb just a little the screws into the holes,be careful and you got it.
Deadman
PostPosted: Fri Mar 10, 2006 12:39 pm    Post subject: Reply with quote
Ok thank you luis.
I'm actually pleased that I missed the Standard one.
I just fancy a black one now.
buckwild
PostPosted: Fri Mar 10, 2006 12:46 pm    Post subject: Reply with quote
I've put several Gibson truss covers on my Tokais. It is not an exact fit. You have to make another hole for it to fit. It has been this way on my LS-200 and LS-320 from about 2001.
Page 1 of 4
