Not flamed veneer love rock models?
ganzua
PostPosted: Sun Feb 19, 2006 7:08 am    Post subject: Not flamed veneer love rock models? Reply with quote
Hi there! This is my first post
Is there any love rock model with solid flamed maple top instead of a carved maple top with a flamed veneer?
hans-j?rgen
PostPosted: Sun Feb 19, 2006 7:18 am    Post subject: Reply with quote
Ask Huttonsteel, he knows all about it... Welcome to the forum! And yes, but they are expensive, old and new.
ZZee ya, Hans-Jürgen
ganzua
PostPosted: Sun Feb 19, 2006 7:33 am    Post subject: Reply with quote
Hi hans, thanks for your response;
So, I presume most of flamed tokai new models are covered with a veneer, aren't they?
Who is Huttonsteel? A forum member?
By the way, I see you are from Hamburg, do you know any tokai dealer in Germany?
Hutton Steel
PostPosted: Sun Feb 19, 2006 8:08 am    Post subject: Reply with quote
Hi ganzua - welcome to the forum! There is a great deal of good advice here to be had on the subject of solid and veneer tops. Do a search on the subject and you can find old threads which have dealt with this question.
hans-jurgen is having a bit of a laugh suggesting that you ask me. There is no better a person to ask than hans-jurgen himself. Togps also knows a fair bit on the subject. After a while on the forums you will get to know everybody's little ways!
All the best!
ganzua
PostPosted: Sun Feb 19, 2006 8:27 am    Post subject: Reply with quote
Hi Hutton!
Thanks for replying
I did some searching before and it seems it is not clear wich models are solid tops. In this thread http://www.tokaiforum.com/viewtopic.php?t=2726&highlight=veneer+tops it is stated that LS-200 and 320 are the only ones with solid flame tops.
Can you confirm that?
I wonder if plain and mahogany tops have highly figured veeners as well ??? Real G**sons are all solid top, aren't they?
Sorry for being a pain
mercman
PostPosted: Sun Feb 19, 2006 8:30 am    Post subject: Reply with quote
New LS150's also have a solid top without the veneer
Les
ganzua
PostPosted: Sun Feb 19, 2006 8:40 am    Post subject: Reply with quote
Les
Thanks mercman. I'm afraid LS-150 tag is in the G**son territory.
Skybone
PostPosted: Sun Feb 19, 2006 10:16 am    Post subject: Reply with quote
FWIW...
The non figured, non veneer models are cheaper, as are the solid colour models. All feature a solid 2 piece maple top on (generally) 2 piece mahogany backs & mahogany necks, and IMO, the plain maple tops (like the big G used to do) make fine guitars with plenty of character.
BUT...
If you are after a flamed top, then the veneer caps DO NOT EFFECT THE TONE OF THE GUITAR. The construction of the veneer models is the same as the other models, 2 piece mahogany back, 2 piece maple top, and a thin flamed veneer on top.
I have 2 Love Rocks at the moment, one is a plain top, the other is a veneer, and IMO, the veneer model actually sounds the better of the two.
ganzua
PostPosted: Sun Feb 19, 2006 10:53 am    Post subject: Reply with quote
Hi Skybone;
So, plain tops are not veener covered? I don't know how the sound is affected by the veener and the glue layer, but if you crack that thin veener I guess the damage will be quite visible.
Plains with no veeners are more appealing to me
Paladin2019
PostPosted: Sun Feb 19, 2006 12:16 pm    Post subject: Reply with quote
ganzua wrote:
Hi Skybone;
I've never, ever heard of a guitar with a 'cracked' veneer. I don't think it's made the way you think.
To answer your question, no the plaintops are NOT veneered - all Japanese tokais have a full thickness maple top, whether plain, veneered or whatever.
BTW, the ls150 is in Gibson territory, yes. However, ? for ? or $ for $ it's much better value. The LS120+ are quite literally Gibson Custom Shop quality for the price of a Les Paul Standard. The LS320 is higher spec than gibson's flagship 59 reissue.
ganzua
PostPosted: Sun Feb 19, 2006 12:24 pm    Post subject: Reply with quote
Hi Paladin2019;
LS120 is veneered?
Paladin2019
PostPosted: Sun Feb 19, 2006 12:27 pm    Post subject: Reply with quote
ganzua wrote:
Hi Paladin2019;
LS120 is veneered?
I believe so, yes.
hans-j?rgen
PostPosted: Sun Feb 19, 2006 12:31 pm    Post subject: Reply with quote
The newer mid-priced (LS80/85-120/125) have a veneer when they are flamed or quilted, but there are also plain top models (LS70/75/80 or the very new LS135 and LS290) without a veneer. Mahogany top LC models in winered don't have a veneer either.
You should decide first if you want a new one or also consider used guitars, because older models usually have better specs with lower model numbers due to inflation.
Furthermore a thin veneer does not change the sound, at least not if the headstock says Gibson and it's "old wood"...
There are only a few shops that actually have some, but probably forum user togps will contact you soon.
ganzua
PostPosted: Sun Feb 19, 2006 1:13 pm    Post subject: Reply with quote
Thanks again Paladin and Hans;
Where do you check the specifications of all those models? Here; http://www.tokairegistry.com/tokai-info/tokai-gibson-models.html LS135 and LS290 do not appear.
I'd like to check all new models, their prices in a japanese shop (a shop that ships to Europe) and then I'll decide if I go Tokai or anyother brand. I'm not a beginner, I'm looking a good les paul but in a budget . And I'm not in hurry.
As a matter of curiosity, which particular model of gibson is veneered?
Skybone
PostPosted: Sun Feb 19, 2006 1:23 pm    Post subject: Reply with quote
Like Paladin said, I have never, ever seen, let alone heard a guitar with a cracked veneer. I would say that it would be very hard to do that kind of damage to a veneer on a guitar, and although I'm no expert in the placement of veneers, I would imagine that to get a veneer to stay in place on a guitar would need a damn good glue and a lot of pressure.
The plain topped guitars such as the older LS60/65 and the newer LS70/75's (I think) are simply plain maple with a coloured finish. Absolutely no veneer.
