Tokai Tweed Amp 1x8"
chrisheyes
PostPosted: Wed Feb 01, 2006 5:33 am    Post subject: Tokai Tweed Amp 1x8" Reply with quote
I finally found one and bought it !!!
Last night I did a sound comparison with my valve Fender Blues Junior
I have to amdit it have an excellent clean tone for a solid state amp. It gives very good strat and tele tones, crunch is not what it was designed for.
Hutton Steel
PostPosted: Wed Feb 01, 2006 11:33 am    Post subject: Reply with quote
You say you did a comparison with a Fender Blues Junior. How did they compare?
chrisheyes
PostPosted: Thu Feb 02, 2006 7:37 am    Post subject: Reply with quote
The little tweed amp gives a better clean tone.
It makes the blues junior sound as if it's got a blanket over the speaker !
Volume wise the BJ will win
Hutton Steel
PostPosted: Thu Feb 02, 2006 9:01 am    Post subject: Reply with quote
If that is the case then I respectfully suggest there is something wrong with your Blues Junior. Have you got it turned up? Does it need new valves? I just do not accept that an 8 inch solid state amp is going to have anywhere near the sound quality of a 12 inch all-valve combo which is used by thousands of players due to it's rich sound. Is it time to take off the Tokai-tinted spectacles? Of course if you prefer the sound of the solid state 8 inch speaker then good luck to you!
chrisheyes
PostPosted: Thu Feb 02, 2006 10:56 am    Post subject: Reply with quote
agreed, the Blues Junior is going to the Tech for a check-up !!
goddardo
PostPosted: Thu Feb 02, 2006 11:12 am    Post subject: Reply with quote
Hi.
I had a Blues Junior, but found it lacking, ie muddy & under powered.
It does sound like mine was in need of a service too, but I didn't have it long. Maybe I should have persevered with it.
I can't see though, how a ss 1x8 combo could compare to an amp like a Blues junior which is a pro gigging amp.
I wouldn't mind the Tokai as a little house amp though. They look pretty cool.
G
Hutton Steel
PostPosted: Thu Feb 02, 2006 11:33 am    Post subject: Reply with quote
Good post goddardo! I think all valve amp owners should pay heed to what you have to say. Many folk with valve amps don't realise that they need looking after. I change valves annually when the amp is being serviced. That way the glorious sound is preserved instead of deteriorating. If you don't want the hassle then go the solid state/modelling amp route. I just don't think there is anything like valves on song!
chrisheyes
PostPosted: Wed Feb 22, 2006 5:18 pm    Post subject: Reply with quote
Hutton Steel
I took your advice and changed the valves in the Blues Juinor. I got
a matched pair of Electro Harmonics EL84
Now the veil has been removed from in front of that amp
Many thanks for the tip
brad347
PostPosted: Wed Feb 22, 2006 10:49 pm    Post subject: Reply with quote
if you think that's good, find some NOS Mullards!
