tenons...were all the love rock/reborns built the same?
bolero
PostPosted: Mon Aug 29, 2005 10:04 pm    Post subject: tenons...were all the love rock/reborns built the same? Reply with quote
just wondering if the neck joint/tenon area was ever done the same as gibson used in the '50's?
all the tokai neck pup cavity pics I have seen have no tenon: the neck stops right at the pup cavity. although there is a bit of a route to make it look similar to the gibson, the heel of the neck doesn't actually extend into the cavity like a 50's gibson
this is the case on my '81 LS60 as well
thx!
bolero
PostPosted: Wed Aug 31, 2005 9:46 am    Post subject: Reply with quote
...someone here must have looked into this?
34 views and no comments? do I have bad breath or something?
cheers
supernout
PostPosted: Wed Aug 31, 2005 10:53 am    Post subject: Reply with quote
either they're laughing or they don't know what a tenon is.
anyway, you are completely right IMO. the 320's and i think older 200's have a long tenon (tongue), i don't know too much about the newer 200's.
supernout
(back in saddle again!)
If you can't solve a problem...you are the problem. (shadocs rule!)
bolero
PostPosted: Wed Aug 31, 2005 2:18 pm    Post subject: Reply with quote
aha, interesting, thx for the reply!!
hans-j?rgen
PostPosted: Wed Aug 31, 2005 3:03 pm    Post subject: Reply with quote
Probably the same question had been answered on that day in another thread, because it's a FAQ anyhow.
No, most models never had a long neck tenon, although ebay sellers think different. The usual neck joint goes up to the cavity and ends there, so it's not a short tenon either, rather a medium tenon. Sometimes there is a fake carving in the cavity bottom to give the impression of a long tenon.
But Tokai also builds Love Rocks with long neck tenons, calling them "deep joint" then. In the 2003-2004 catalog this term can be found for the LS120 and LS320, but not for the LS200. This could mean that the LS200 neck is really different from the other two, perhaps because of the ebony fretboard which might have been originally designed for the LC models and now has to be used up. But I'm completely guessing here, so maybe the new LS200 also has this neck tenon, and Tokai only didn't mention it in the catalog.
ZZee ya, Hans-Jürgen
bolero
PostPosted: Wed Aug 31, 2005 7:34 pm    Post subject: Reply with quote
hmm, I looked & didn't see anything in the FAQ's about this....but I did just do a thread search & found some info:
http://www.tokaiforum.com/search.php?search_id=1572445862&start=25
thx for the *new* info though, there wasn't much definitive in those posts
cheers
hans-j?rgen
PostPosted: Wed Aug 31, 2005 11:06 pm    Post subject: Reply with quote
OK, I meant it comes up regularly in the forum, not the FAQs on the main site.
The link doesn't work, it should contain a thread or post id. A good search term probably is "tenon".
I've never seen a photo of a new LS320 or LS120 with the "deep joint" neck, only several with the usual medium neck tenon. By the way, I think this word does not only mean the tongue underneath the neck pickup cavity, but the whole piece of neck wood under the fretboard which is roughly carved in a slight V-shape to fit into the body.
Here are some pictures that show a short vs. a long tenon, made and published by Gibson, as far as I know, to illustrate the difference of a Historic Reissue with long tenon vs. a normal Les Paul Standard:
Here's the LPF thread where I found them:
http://www.lespaulforum.com/forum/showthread.php?t=98748
By the way, I'd like to know what that light colored piece of wood between the fretboard and the truss rod is in the Standard picture, looks like a slice of maple to me... Or is this the usual method for filling the truss rod cutout?
Answering my own question: obviously yes, because in the upper picture the Historic shows a square light colored piece of wood at the end, too. So the saw just didn't cut these guitars in two exactly equal pieces.
spikeymikey
PostPosted: Thu Sep 01, 2005 10:50 am    Post subject: tenon Reply with quote
Side by side with a Gibson historic my '79 LP Reborn seems to have the exact same joint from comparing the neck cavities anyhow. Gonna try to bust into the local hospital tonight and play with their X-Ray machine
hans-j?rgen
PostPosted: Thu Sep 01, 2005 10:57 am    Post subject: Reply with quote
Good idea... and send pix!
Paladin2019
PostPosted: Thu Sep 01, 2005 4:22 pm    Post subject: Reply with quote
supernout
The new 200's don't have the full length tenon, but it extends to the end of the neck. The question is, does an extra half-inch lip of wood really make that much difference in tone? I reckon not, but it is a 'vintage correct' detail that some people consider important.
Mine appears to be a two-piece tenon, with a second bit of wood under the main body of the tenon. My theory is that this is actually a very large shim. The neck tenon would be cut to size, then the shim part shaped so the neck perfectly fits the neck pocket. This would eliminate the risky and labour intensive business of percetly shaping a full size long tenon.
hans-j?rgen
PostPosted: Thu Sep 01, 2005 10:22 pm    Post subject: Reply with quote
Right, and very interesting about your new LS200, thanks for sharing the info. Another aspect about that endless tenon saga is that the long tenon isn't just longer, but also broader, so the contact between the neck and the body wood is supposed to be much tighter with less glue which should enhance a better transport of the neck vibrations into the body. I agree with that when looking at the available Gibson pictures, but concerning the medium tenon of Tokai guitars I would say it is close in that respect, too.
