Got a serial # before 8000349?
loverockerUK
Post by loverockerUK » Mon Mar 08, 2004 4:45 am
null
ned
Post by ned » Mon Mar 08, 2004 6:17 pm
lrUK-
Is that on a Reborn model? If so it would be a 1978 model. First digit = year up to 89.
Ned
loverockerUK
Post by loverockerUK » Tue Mar 09, 2004 3:04 am
null
supernout
Post by supernout » Tue Mar 09, 2004 12:53 pm
The LPS/LPC thing started officially back in ’78 (catalog vol.1).
The 010.... guitars must be from ’81. It’s a different production run and a different body construction & hardware as far as I can recall, probably built somewhere else (Fernandes or Greco?). I haven’t seen any impressed serial starting with 010...., only inked on ones’.
The serialisation scheme ended in ’85 ? and went from 501 up to 504. Hypothesis is that these four production runs were made throughout ’85 – ‘88. I don’t believe that they built all the guitars in only one year.
Or... did they have a break during those years?
If you can't solve a problem...you are the problem. (shadocs rule!)
sneakyjapan
Post by sneakyjapan » Tue Mar 09, 2004 6:34 pm
my LS60, LP Reborn from 1978 has the serial number of... 8000316.
loverockerUK
Post by loverockerUK » Wed Mar 10, 2004 3:04 am
null
sneakyjapan
Post by sneakyjapan » Wed Mar 10, 2004 7:06 am
yes to the double rings but it didn`t have a truss rod cover so I bought one. One of the tuners had been changed. Hey...it`s old. Thats not all.... previous owner swapped the pickups to Duncan Alnico Pro II`s and it has 3 pull up pots. Gives it a lot of tonal possibilities. I`m on the look out for a non modifid model, and am confident I will find one. I`d like a high end guitar, so I`m holding out.
supernout
Post by supernout » Wed Mar 10, 2004 10:46 am
sneakyjapan wrote:my LS60, LP Reborn from 1978 has the serial number of... 8000316.
with a 2p neck? :o
Tokai Mad says, if I remember correctly, Tokai restarted in '76 with electrics.
Strat copies started in '77 and have 700....serials. There are known to exist a few LP prototypes without any serial built before '78.
loverockerUK
Post by loverockerUK » Wed Mar 10, 2004 10:59 am
null
sneakyjapan
Post by sneakyjapan » Wed Mar 10, 2004 6:19 pm
2 piece neck, one piece back.
