Narrow neckplate on Springy Sound
Tokai guitar discussion
tokaiplusmarshall
Post by tokaiplusmarshall » Fri Oct 31, 2003 8:20 am
Does anyone have any info on Springy Sounds that have narrow neckplates? I saw one, but I couldn't find a serial number anywhere.
Springy is here again..
woof
Post by woof » Mon Nov 03, 2003 3:11 am
define "narrow neckplate" ....do you mean the type that has a black rubber gasket underneath? i have a springy and a gold and both have stock vintage type neckplates and both have serials on the plates....
tokaiplusmarshall
Post by tokaiplusmarshall » Mon Nov 03, 2003 10:45 am
I've never seen a Springy with a gasket, but the one I'm talking about has a neckplate that is a 1/4" or so narrower. I think the earliest (78) Springys had those. The serial would then be in the neck pocket. I saw a white one on Ebay now...wow the guy is asking a lot for it.
loverockerUK
Post by loverockerUK » Mon Nov 03, 2003 5:01 pm
null
tokaiplusmarshall
Post by tokaiplusmarshall » Tue Nov 04, 2003 5:17 am
Check out the neckplate on the one below. No serial, narrow. Maybe they were made for a limited time in '78, not sure though. LoverockerUK, do you mind telling me what the serial is on your '78 Springy- or just the first 2 numbers? Thanks.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... otohosting
loverockerUK
Post by loverockerUK » Tue Nov 04, 2003 1:23 pm
null
Ned B
Post by Ned B » Tue Nov 04, 2003 6:56 pm
I have a '78 ST80 that I thought was pretty early with 80018XX as a serial number, so are these "pre-serial number" STs well documented?
tokaiplusmarshall
Post by tokaiplusmarshall » Thu Nov 06, 2003 6:56 am
Unfortunately I haven't found much info on these Springys. They do have serials...just not stamped on the neckplate. It's stamped in the body neck pocket. I only just discovered these narrow n.p. Springys last week.
