What LP Reborn compares to a Standard?
theflyingturtle
PostPosted: Fri Jul 21, 2017 1:03 pm    Post subject: What LP Reborn compares to a Standard? Reply with quote
Hi! I'm a new member. I became interested in buying a LP style guitars but would rather it be a different brand than Gibson and Tokai, as far as I know, has produced some very well regarded guitars. Their history is also nebulous as well! If I had a nickle for every incorrecly labled "lawsuit" guitar on Craigslist I could retire. So I have done some research and it seems that the 78'-80' LP Reborns as some of the most highly regarded. This is my question; Which model from LS-50 to LS-200 is comparable to a Gibson "standard"? Thanks.
J.E.M.
PostPosted: Fri Jul 21, 2017 1:13 pm    Post subject: Reply with quote
I'd think in those years everything above a 60 is as good, certainly at 100 Tokai's are better than a Gibby standard made back then or now.
theflyingturtle
PostPosted: Fri Jul 21, 2017 4:01 pm    Post subject: Reply with quote
Excellent! Thank you very much. The LS 50 and LS 60, are these closer to a Studio? I ask because when trying out LPs everything below a Standard didn't sound or feel very good.
aroomstudios
PostPosted: Sat Jul 22, 2017 7:36 am    Post subject: Reply with quote
LS 50 and 60 have multi piece backs. I would get a LS80 or above. The only difference I know from LS80 to LS 100 is the pickup and a higher lacquer top. If you are planning on installing new picks it does not matter what you get (ls80 or above). I have heard that up to 1981 they were made the exact same as the 79 models. I have a Burny Tokai made custom 78 similar to LS80/100 and a 81 Ls80.
PostPosted: Sat Jul 22, 2017 11:04 am    Post subject: Reply with quote
the only difference between 80 and 100 is the pickups, the difference between a new Gibbo standard and an ls 80 is vast the tokai does not have weight relief holes, or kiln dried new growth wood or poor finishing.. an LS80 is far superior..
theflyingturtle
PostPosted: Sat Jul 22, 2017 11:55 am    Post subject: Reply with quote
Great! Thank you so much! This helps a lot! Finding info on these MIJ guitars has been a real challenge so far.
