1981 ES150...the journey begins!
BrianGT
PostPosted: Thu Jun 22, 2017 2:07 am    Post subject: 1981 ES150...the journey begins! Reply with quote
Well, the autopsy begins!
I really like this guitar. It has a big round neck and it sounds wonderful acoustically. The wood has really dried out over the years and it has a very sharp snap when you tap it.....like a really nicely tuned snare drum.
The only let down is that the pickups have weakened over time. They sound wonderfully sweet with absolutely no harshness but they have the output of a single coil. Raising them has only helped slightly and after speaking to Spence he reckons that the magnets need re-charging. I have removed them to send away.
I have fitted OTPG's to my 135 and it sounds fabulous. Just like a really good semi should sound like, big, open and dynamic so that is the guitar that I pick up the most.
However, I love the ES150 so the journey had to begin!
I bought a set of aged Dimarzio 36th Anniversary Paf's in nickel to try out whilst the pickups are away and also to see if the lower volume really was just the pickups.
I discovered the largest "Orange Drop" capacitors I have ever seen!
The pots are full size and A500k volume and B500k tone. By the amount of crud on the pot shafts they had never been out.
I fitted the new pickups , guessed at the height to set them at and re-strung the guitar. Immediately whilst tuning I knew I had a much better volume.
I've read a lot of reviews on these pickups and whilst I have never bought Dimarzio pickups before these are superb in this guitar! They really do sound great with a very PAF like voice. Glad I pulled the trigger on these.
The guitar is alive again and a joy to play and listen to and is now up to par with my other two Tokai semi's as far as output is concerned. They also look the part too! If the originals still don't come up to par after being tweaked I have a great sounding guitar anyway and that's all that counts. It wasn't original when I bought it so no harm done but it's now a great guitar.
Orange would you say??
Dimarzio 36th Anniversary PAF's fitted. They blend in well.
The original 1981 Dimarzio PAF's.
Back together again.
and in her rightful place....Centre stage!
Emiel
PostPosted: Thu Jun 22, 2017 5:24 am    Post subject: Reply with quote
Wonderful stuff, Bryan!
Was it hard to take out the pots and replace the pickups? I am about to do the very same
BrianGT
PostPosted: Thu Jun 22, 2017 6:23 am    Post subject: Reply with quote
It was actually very easy!
There was enough wire attached to the switch tags to allow the pots to come out of the F-holes. The pots were hardwired to each other by those huge caps which meant they didn't twist about and came out easily.
In this case, probably the easiest I have ever done on a semi!
I have been playing it all morning and I am blown away with the new pickups!
PostPosted: Thu Jun 22, 2017 6:31 am    Post subject: Reply with quote
tie string around the pot shafts on top before dropping them, makes it easy to get them back in...
PostPosted: Thu Jun 22, 2017 6:42 am    Post subject: Reply with quote
Fabulous
PostPosted: Thu Jun 22, 2017 10:23 am    Post subject: Reply with quote
Holy trinity of 335's. That's a hella sweet Old Red.
