Tokai ES135 with Duesenberg Les Trem 2
BrianGT
PostPosted: Sat May 27, 2017 2:09 am    Post subject: Tokai ES135 with Duesenberg Les Trem 2 Reply with quote
I fitted this Duesenberg Trem to my 135 and I have to say it is great!
It just replaces the tailpiece, no drilling, and can be removed next string change in 15 seconds if I want to go back to original.
It is well made and works really well. I use 10-46 strings and the spring size and tension is spot on so it stays in tune.
It's lighter than a Bigsby to use but not light enough to go flat when you bend the G string a tone and fret the B string together.
I just love how it is so easy to fit/remove.....will I keep it on this string change or not.
Hasn't seemed to alter the tone or feel and of course intonation stays the same as you use your original bridge.
PostPosted: Sat May 27, 2017 3:30 pm    Post subject: Reply with quote
Very classy look.
BrianGT
PostPosted: Sun May 28, 2017 2:31 am    Post subject: Reply with quote
felixcatus wrote:
Very classy look.
Thanks Felix!
I think when you look at the alternatives out there it is indeed quite classy and for 80 Euro it's cheap!!
Some just look way over-engineered.
I'm going to put it on the 158 next string change.
PostPosted: Mon May 29, 2017 5:24 am    Post subject: Reply with quote
Good idea for those in need of some vibrato. Did the notes come back to pitch? I have read they do not in Vibrolas placed on 60's SGs among other Gibsons...
BrianGT
PostPosted: Mon May 29, 2017 6:25 am    Post subject: Reply with quote
It stays in tune really well.
I lubed the nut with vaseline and I have had no issues. I do only use it as a warble kind of thing...no dive bombs!
