Replacement Tone pots for 2008 es130
prudd
PostPosted: Fri May 12, 2017 3:26 am    Post subject: Replacement Tone pots for 2008 es130 Reply with quote
Hi all,
I need to replace the tone pots on a 2008 es130, want the best quality I can get, any suggestions, do I have to be carefull about the diameter of the shaft?
I'm in the UK.
Thanks
Paladin2019
PostPosted: Fri May 12, 2017 5:38 am    Post subject: Reply with quote
CTS pots are considered the standard for high quality guitar pots. I would advise replacing all of your pots rather than just the tone controls for the simple reason that different makes and models of pot feel different - different torque, different smoothness, different taper. Personally I'd want consistency.
You would have to check the diameter of the holes, but CTS make pots with metric shafts these days so it should just be a case of ordering the right version. This would also mean you could re-use your current knobs instead of buying new.
What issues are you having with the current pots? You may be able to sort things out without resorting to replacements.
dombat
PostPosted: Fri May 12, 2017 11:36 am    Post subject: Reply with quote
CTS, as well as any potentiometer manufacturer has several lines of products, quality wyse.
They have very good quality products, as well as quite low end ones.
Considering Tokai guitars, I'd recommend japanese Alpha pots, which do not have to be shy against CTS ones.
prudd
PostPosted: Sun May 21, 2017 6:08 am    Post subject: Reply with quote
thanks for your help, one of the pots has just stopped working , no crackle, doesnt seem to be affecting the rest of the electrics at all.
Paladin2019
PostPosted: Sun May 21, 2017 6:29 am    Post subject: Reply with quote
Not telling you to change your plans but this sounds like a repair job to me rather than a replacement. It may well be a faulty connection rather than a bad pot.
prudd
PostPosted: Wed May 24, 2017 10:54 am    Post subject: Reply with quote
Yes, thanks, I think your right, i will look into it, shame that its such a pain getting to the pots on a 335.
