Tokai Goldstar Sound
radziu_t
PostPosted: Mon Nov 14, 2016 3:56 pm    Post subject: Tokai Goldstar Sound Reply with quote
Hello, can you help me on a Tokai Goldstar Sound? The seller says it has no serial becuase "Tokai stopped putting serial numbers on their Japanese models at the end of the 80's, so it's probably between 1990-95, but could be a bit later.. " Can you confirm if this is true? Can you also confirm based on the photos if it's a genuine Japanese Tokai
http://www.aukcjoner.pl/gallery-demo/24501866.html
radziu_t
PostPosted: Mon Nov 14, 2016 4:07 pm    Post subject: Reply with quote
PostPosted: Tue Nov 15, 2016 9:11 am    Post subject: Reply with quote
I have a breezy sound with no serial from around 2009 so there has been times the neck plate had no serial or the neck itself. If i were you though i'd want some gut shots of the body to make sure it is in fact a tokai body. There should be tokai codes inside the body if it is an older model.
