1981 Greco SE with Fender JV Body?
CliffsComicWorld
PostPosted: Thu May 05, 2016 10:42 pm    Post subject: 1981 Greco SE with Fender JV Body? Reply with quote
Aloha... I know that the Fender JV's started in 1982... so here is a December 1981 Greco Strat with Fender markings in the neck pocket.. ???? The Pick guard is November 21, 1981, 2 piece center seam body. Pickguard is plastic. Pickups are marked "31276" I assume these are Excel Pups.... My thinking is .. maybe this is a JV Body??? or what do I have here?... Thanks... Cliff
PostPosted: Fri May 06, 2016 1:45 am    Post subject: Reply with quote
its only a jv body if it has the correct routing for the wires in the front pu cavity and the deeper cut, i think its a greco body with a fender shim...
dombat
PostPosted: Fri May 06, 2016 2:53 am    Post subject: Reply with quote
+1
CliffsComicWorld
PostPosted: Fri May 06, 2016 7:59 am    Post subject: Reply with quote
Model number?
PostPosted: Sat May 07, 2016 5:43 am    Post subject: Reply with quote
no idea
wulfman
PostPosted: Sun May 08, 2016 7:17 pm    Post subject: Reply with quote
Usually the neck pockets of the Grecos have a number to denote the model like 5 for 500, 6 for 600 and 8 for 800. It could be that the body is not from a Greco and is from a Fender.
Super Sound is normally an SE-600.
PostPosted: Sun May 08, 2016 8:32 pm    Post subject: Reply with quote
I'm no expert but i have almost the same guitar, but from one month earlier. K serial '81 supersound. I guess you can compare the two if you please.
