V neck and printing on neck and cavity
crazdog
PostPosted: Sun Oct 11, 2015 10:52 pm    Post subject: V neck and printing on neck and cavity Reply with quote
Hello members tks you help! I have a V neck on tokai SS were these necks only used on higher end guitars like ST-80 and above. And the lettering on end butt of neck and inside cavity body supposed to be same. Indicating original neck and body same.. If not what do these letters and numbers represent...ie. 4=1A on neck and 5=5 GS body thanks your help !
PostPosted: Mon Oct 12, 2015 9:27 am    Post subject: Re: V neck and printing on neck and cavity Reply with quote
Codes don't have to match for the guitar to be original.
I mailed Tokai directly, and this is their response:
"Dear Customer,
Thanks for loving Tokai Gakki.
From the feature you explained, the guitar is made by Tokai at the time.
The code No. on the body and neck express lot number.
>-body code: 6=14 A
Made in June.
>-neck code: 5=16 A
Made in May.
I hope this info hellps you.
Best regards.
Tokai Gakki Co.Ltd
And (let's end this once and for all ) PROOF of an original Tokai (body/neck) with non matching codes!
crazdog
PostPosted: Mon Oct 12, 2015 4:57 pm    Post subject: Reply with quote
Tks your help really helpful tks!
bluejeannot
PostPosted: Wed Oct 14, 2015 5:58 pm    Post subject: Re: V neck and printing on neck and cavity Reply with quote
"Dear Customer,
>-body code: 6=14 A
Made in June.
>-neck code: 5=16 A
Made in May.
Best regards.
Tokai Gakki Co.Ltd
Absolutely spot on.the neck and body coded do not neccessarily have to match for a Tokai to be original.
bluejeannot
crazdog
PostPosted: Wed Oct 14, 2015 7:29 pm    Post subject: Tks Reply with quote
Tks u help.. Might if V necks were only used for ST 80 and above... Tks
