Have anyone changed the wiring in a high end Tokai?
ibicus
PostPosted: Mon Jun 29, 2015 3:04 am    Post subject: Union Jack Breezy MIJ ??? Reply with quote
And the serial starts with a C...
http://www.ebay.de/itm/Tokai-TTE-70-Breezy-Sound-Telecaster-2006-MIJ-Union-Jack-Rare-/141684663532?
PostPosted: Mon Jun 29, 2015 7:21 am    Post subject: Reply with quote
Wonder if they have the Confederate flag model for US distribution
ibicus
PostPosted: Mon Jun 29, 2015 7:51 am    Post subject: Reply with quote
Well if they call it Warren Haynes Signature Breezy
Do you think it is a fake ? The seller says he bought it from tokai outlet Tokyo...
PostPosted: Mon Jun 29, 2015 9:47 am    Post subject: Reply with quote
Hard to tell if it's a fake or not being from China....
ibicus
PostPosted: Mon Jun 29, 2015 11:21 am    Post subject: Reply with quote
But the number says it is chinese ?
PostPosted: Mon Jun 29, 2015 12:44 pm    Post subject: Reply with quote
Yes
Esbenmad
PostPosted: Mon Jul 13, 2015 12:15 pm    Post subject: Have anyone changed the wiring in a high end Tokai? Reply with quote
Hi
I just purchased a used Tokai HES 180 and I am very pleased with it. Amazing guitar of an amazing quality. Especially the acoustic qualities of the guitar are great and a great deal better than my Ibanez AS93. However I have decided to change the pickups to Sheptone Tributes. I have them in the Ibanez and they just sound better to my ears - more air and woodyness while the Fiftynines in the Tokai are to fat sounding for my liking. So a recommendation for the Sheptone Tributes if you like a woody tone
But now to the question: I changed the wiring harness in the Ibanez to one from Jonesyblues that is clearly a lot better than the stock wiring. I am considering to do the same with the Tokai, but I know that Tokai are very focused on detail and quality, and it seems they use Switchcraft and CTS, so I guess the change would be unnoticable. Have any of you guys switched the wiring in your high end Tokai, and have you noticed any difference?
Thank you
All the best, Esben
Paladin2019
PostPosted: Mon Jul 13, 2015 4:49 pm    Post subject: Re: Have anyone changed the wiring in a high end Tokai? Reply with quote
Switchcraft/CTS are already as good as it gets so if you're just swapping things out for the sake of 'improvement' then you are wasting your time.
If you're modifying the circuit - different pot values, extra switches etc. - then that's different, you would be changing the tone or gaining functionality that the stock components can't provide.
Esbenmad
PostPosted: Tue Jul 14, 2015 1:49 am    Post subject: Reply with quote
Thank you for your answer
That was just what I needed to hear. I just wanted to be sure - I dont want to do an operation to this guitar more than once. It is really timeconsuming pulling everything out from that f-hole
A lot of people change the wiring on their expensive Gibsons, but I guess Tokai just has a better standard
Richard
PostPosted: Sun Jul 19, 2015 9:12 am    Post subject: wiring Reply with quote
Pointless changing the wiring in a high spec Tokai - and you're right about Gibson wiring, my Gibsons wiring is like a birds nest with birdshit soldering compared to the perfection and neatness of Tokai. The woodwork is much better on Tokai too - the cavities on my Gibson look like they have been chewed out by a rabid rat, compared to the accurate, smooth cutting on my Tokai..........
Esbenmad
PostPosted: Sun Jul 19, 2015 9:19 am    Post subject: Reply with quote
Thank you for your answer. It is good to hear that there is no need for that. It sure does look neat, from what I can see through the f-hole
Mick51
PostPosted: Mon Jul 20, 2015 10:58 am    Post subject: Re: Have anyone changed the wiring in a high end Tokai? Reply with quote
I guess that I would respectfully disagree. CTS makes a raft of pots, and tolerance and taper are both variables. I don't think that it is quite as cut and dried as you are indicating. The real bottom line is: Are you satisfied with what you are hearing? Ultimately, the ears answer the question. Certainly, if you're satisfied with the tone and range, there is no reason to swap out the electronics.
Paladin2019
PostPosted: Mon Jul 20, 2015 3:58 pm    Post subject: Re: Have anyone changed the wiring in a high end Tokai? Reply with quote
I think that's pretty much what I was trying to say anyway!
