Tokai Strat ?????
funkilius
PostPosted: Wed Jun 03, 2015 2:30 pm    Post subject: Tokai Strat ????? Reply with quote
Expert opinions appreciated on this one please...
http://www.ebay.ie/itm/131527979497?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
thanks in advance........
bluejeannot
PostPosted: Mon Jun 08, 2015 5:17 pm    Post subject: Reply with quote
St 40 based Bitsocaster,with ceramic pickups and what looks like original neck plate.The neck should should have lam board not slab like this one which means it is not original and the saddles should be pressed steel not solid mazac.Vastly overpriced.Avoid.Gabe
bluejeannot
funkilius
PostPosted: Tue Jun 09, 2015 11:09 am    Post subject: Reply with quote
thanks for info
certainly overpriced............
as a matter of interest....................how to tell difference between lam and slab board ????
japaxes
PostPosted: Tue Jun 09, 2015 11:39 am    Post subject: Reply with quote
if you look at the amount of wood showing on the fretboard to headstock side behind the nut .on a lam board there is very little and it generaly curves.
whereas on a slab board it is straighter and wider
funkilius
PostPosted: Wed Jun 10, 2015 3:06 pm    Post subject: Reply with quote
ok....got it........thanks.....
