NGD LS-80 "Reborn Old"
duaneflowers
Post by duaneflowers » Mon Nov 17, 2014 10:37 pm
Just in...
Reborn Old
Post by Reborn Old » Tue Nov 18, 2014 6:26 pm
Very nice example and in great condition, by the looks of it Duane. Congrats !
Was that the LS-80 listed on J-Guitar a week or two ago ?
duaneflowers
Post by duaneflowers » Tue Nov 18, 2014 8:01 pm
Reborn Old wrote:Very nice example and in great condition, by the looks of it Duane. Congrats !
I didn't notice the one on J-Guitar... this one was "briefly" on Yahoo Auctions...
It is in great shape, as is the original case... the case that came with my LS-120 was in terrible condition... but luckily the guitar was not. :D
duaneflowers
Post by duaneflowers » Wed Nov 19, 2014 1:14 am
Thinking of replacing the tuners on this puppy... anyone know of a drop in replacement?
TIA 8)
Reborn Old
Post by Reborn Old » Wed Nov 19, 2014 7:44 am
If you want new tuners, I would think any kluson set off eBay, Stewmac or AllParts would work. Yahoo for newer used.
duaneflowers
Post by duaneflowers » Wed Nov 19, 2014 9:23 am
Reborn Old wrote:If you want new tuners, I would think any kluson set off eBay, Stewmac or AllParts would work. Yahoo for newer used.
Cool! Are they pretty much-one-size-fits-all? The Tokai "Klusons" and Original Klusons are interchangeable? For example, These would work with no problem?[/url]
Reborn Old
Post by Reborn Old » Wed Nov 19, 2014 12:07 pm
Yes, they would work .. I'm pretty sure.
I have a set of 1960 Gibson LP tuners that these Klusons would replace,
and both vintage Gibson + Tokai have 23.3mm tuner mount screw spacing, center to center.
AFAIK only gear ratios have changed. British + Metric shaft sizes might vary slightly.
wulfman
Post by wulfman » Wed Nov 19, 2014 5:01 pm
A pair of these should be fine. I used them on an LS-100 with no mounting issues.
http://page6.auctions.yahoo.co.jp/jp/auction/f141242122
duaneflowers
Post by duaneflowers » Wed Nov 19, 2014 7:58 pm
Awesome! Thanks again guys!! :P
Post by Sigmania » Wed Nov 19, 2014 9:10 pm
Why are you replacing them? If they are not factory tuners, then the holes may have been reamed out for modern hole diameter?
I put a set of Tone Pro Kluson style tuners in my guitar that had been slightly reamed to accept Grover Rotomatics. They work great.
Regards, Geoff
duaneflowers
Post by duaneflowers » Wed Nov 19, 2014 9:43 pm
Sigmania wrote:Why are you replacing them? If they are not factory tuners, then the holes may have been reamed out for modern hole diameter?
One of the tuning pegs on my LS-120 is a little loose. It works perfectly and keeps tune just fine but it was like that when I got it. I don't know anything about the mechanisms or gears inside but I'd like to preserve them as much as possible. So I want to replace them and keep the original set in case I ever decide to part with it... which I have no plan to do as its a magnificent guitar!
Post by luis » Thu Nov 20, 2014 4:47 am
duane, the posts in old Tokai turnesr is slightly fatter than recent Gotoh Klusons ones.
I have put Goldo by Gotoh ones with Deluxe stampedletters and it fits altough not an exact replacement. I have to replace one in my 1996 LS-320 converted to 59 specs (hardware and plastics) someone forgot to mention it was not OK. A 70 and 80s will fit in OK.
Post by Sigmania » Thu Nov 20, 2014 5:37 pm
If you have calipers its easy to figure out. Just measure your hole.
Most listings will give you the diameter of the bushings or posts.
Regards, Geoff
duaneflowers
Post by duaneflowers » Sat Nov 29, 2014 12:44 am
wulfman wrote:A pair of these should be fine. I used them on an LS-100 with no mounting issues.
Got a set of these and hope to get around to installing them this weekend...
Thanks again for the help guys! :)
wulfman
Post by wulfman » Sat Nov 29, 2014 4:38 am
Good to hear. I had no issued putting them in.
