Tokai Jazz Bass - what year?
Dill_Alone
Post by Dill_Alone » Wed Sep 24, 2014 2:37 am
Hi there!
I've got this Tokai Jazz Bass bought through some musician forum. I don't know what is its year. And that bass has... changes looking wierd. You may see it by photo #3 (with SN). Its fingerboard, the opposite side. Why did they do this? Is that fingerboard original or not? And how can I find out the production year? Thanks.
Post by jacco » Wed Sep 24, 2014 6:33 am
That's a late 1981 model.
Neck heel was shaved to get better access to the higher frets
Dill_Alone
Post by Dill_Alone » Wed Sep 24, 2014 7:48 am
You helped alot. Thank you!
The output signal level is pretty low. That's my first passive bass so I have no idea is it normal or not. Should I clean the contacts, replace wires and regulators? Or maybe it is caused by misplaced strings? I'm not sure I did it right while changing them. :oops:
But the sound of that bass is awesome! I would never regret that purchase! <3
bluejeannot
Post by bluejeannot » Wed Sep 24, 2014 6:25 pm
Lower output is normal for a passive bass.turn up your amp.Fabulous bass you have there!Gabe.
bluejeannot
bbuhlman
Post by bbuhlman » Fri Oct 10, 2014 11:37 pm
Or the neck is not original and it was shaved to get the correct string height. I've done this to make necks play well that are not original.
Post by jacco » Sat Oct 11, 2014 12:04 am
That would only be possible if the body isn't Tokai. The neck is from that timeframe.
Post by Sigmania » Sat Oct 11, 2014 3:01 pm
Nice. Here is mine which I thought was a 1981 as well. Anyone know?
Regards, Geoff
Post by jacco » Sat Oct 11, 2014 4:18 pm
Hi Geoff, that one is from 1982
Post by Sigmania » Sat Oct 11, 2014 6:47 pm
Thanks jacco!
Regards, Geoff
