Reborn humbucker surround screws source
ChrisB
PostPosted: Tue Apr 22, 2014 12:23 pm    Post subject: Reborn humbucker surround screws source Reply with quote
Hi, does anyone have a source for pickup surround mounting screws for a Tokai Reborn. The head seems to be smaller than the ones available on ebay etc - about 4mm? Need short and long for both pickups.
Thanks
PostPosted: Wed Apr 23, 2014 4:36 am    Post subject: Reply with quote
Chris, I would check Allparts or Gotoh. Tokai screws are smaller in diameter than the original 50 ones (Gil yaron can supply some set similar to them).
I can confirm the ones from MusicElectronics in USA are longer and the ones from Thonman Germany are longer than MusicElectronics.Can order small ones and putb them in all positions.
I have put the ones from MusicElectronics with sucess in a 80s Tokai recently.
http://www.guitarelectronics.com/category/parts___hardware.screws___springs/
http://www.guitarelectronics.com/product/SCHB3S-24/Short-Humbucker-Mounting-Ring-Screws-Nickel.html
http://www.allparts.uk.com/collections/pickup-surround-screws
http://www.thomann.de/es/thomann_humbuckerframe_screw_set_n_ni.htm
http://www.thomann.de/es/thomann_humbuckerframe_screw_set_b_ni.htm
ChrisB
PostPosted: Wed Apr 23, 2014 9:51 am    Post subject: Reply with quote
wow, thanks for that Luis. The allparts ones look close so went ahead and ordered short and long of those to see if they do the trick.
Cheers
PostPosted: Wed Apr 23, 2014 9:52 am    Post subject: Reply with quote
I used to buy alot of parts from this guy, Andy, when I was heavy into Ibanez. He may be able to help? Especially if you have the dimensions of the screws.
http://www.reproguitarparts.com/
Regards, Geoff
PostPosted: Wed Apr 23, 2014 10:50 am    Post subject: Reply with quote
My pleasure Chris, glad to help you.
ChrisB
PostPosted: Fri Apr 25, 2014 5:16 am    Post subject: Reply with quote
For future ref - the Allparts screws listed above are perfect and took one day to get here.
Thanks again guys, much appreciated.
