Help dating Tokai Breezysound
tomtwothree
PostPosted: Mon Apr 21, 2014 4:46 am    Post subject: Help dating Tokai Breezysound Reply with quote
I would appreciate some help dating/find model no. of this:
http://m.ebay.co.uk/itm/161277599821
Thanks
tomtwothree
PostPosted: Thu Apr 24, 2014 5:51 am    Post subject: Reply with quote
Any feedback on this appreciated, thanks
Len
PostPosted: Thu Apr 24, 2014 1:14 pm    Post subject: Reply with quote
it?s a TE-50.
Looks legit.
Serial is the right type for a rw board TE-50. It?s more likely a 1984/85 guitar than 1983, but the serial does not provide exact info about that.
Logo looks to be positioned a bit far on the right, but that does not have to mean anything
specs are usually:
2-3 piece body + poly finish
U-Neck
TEB-Pickups
tomtwothree
PostPosted: Thu Apr 24, 2014 3:52 pm    Post subject: Reply with quote
Thanks so much for the feedback. I also noticed the far-right positioning of the logo decal and thought this was a bit odd!
Len
PostPosted: Thu Apr 24, 2014 4:38 pm    Post subject: Reply with quote
yes, it looks odd. If the logo is original or a repro .. I can?t tell
I have logged another TE-50 with rw board with a similar serial number (L103xx) and the logo is positioned a bit differently
Tokai "T" starts where the D-tuner is located
can send you a pic if you PM me your email
the rest of the guitar & electronics look authentic to me
the stamp in the electronics cavity looks right, too
if it?s not to late try to ask the seller for other body / neck stamps & if there are stamps on the back of the pickups
tomtwothree
PostPosted: Fri Apr 25, 2014 2:22 pm    Post subject: Reply with quote
Hi Len,
The seller gave me this info when I asked:
"All I can see is BL 4=4. I assume this is BL for blonde and 4/4 scale of guitar? I haven't looked under the bridge pickup but can't see nothing under the neck pickup."
I'm keen to ensure it's genuine before bidding and is an 83-85 model. Whatcha recon?
Thanks
Len
PostPosted: Fri Apr 25, 2014 5:32 pm    Post subject: Reply with quote
BL means Blonde
4=4 is a Tokai production code , there should be a similar or matching stamp on the neck heel
tomtwothree
PostPosted: Sat Apr 26, 2014 2:24 am    Post subject: Reply with quote
Do you think it's legit? Only a few hours left of the auction you see
Len
PostPosted: Sat Apr 26, 2014 3:03 am    Post subject: Reply with quote
I can?t give you a guarantee of course...
..for me all looks legit for an 80s TE-50, except the logo positioning which looks a bit odd
can?t help you with more details than already listed in the previous posts
there are a few things that would be good to know (photos of the pickups, cavities, neck heel stamp)
pickups should have TEB stamped underneath but stamps can wear out or pickups can be changed
wiring (switch, pots, capacitors) looks exactly like on other mid 80s TE-50s that I?ve seen as I said before
as you see there is also a little ?treble bleed? capacitor next to the green one. that is part of the original wiring Tokai used back in the 80s
tomtwothree
PostPosted: Sat Apr 26, 2014 3:38 am    Post subject: Reply with quote
Thanks so much for the help Len, really appreciated!
