1980 LS80 Pickups Keep or Replace?
fatherjones
PostPosted: Sat Mar 29, 2014 9:16 am    Post subject: 1980 LS80 Pickups Keep or Replace? Reply with quote
I have always liked 57 Classics by Gibson. But the S marked PAFs by 'Goto' arent bad. Should I keep this guitar all original to preserve collector value? I know its a subjective question. But I ask y'all...what would you do?
wulfman
PostPosted: Sat Mar 29, 2014 10:17 am    Post subject: Reply with quote
I think you can pretty safely change them out and not worry too much about the value of the guitar. I think the consensus would be that the pickups are not the main attraction of the early Tokais.
Mono
PostPosted: Sat Mar 29, 2014 5:07 pm    Post subject: Reply with quote
pickup swaps are very common in ls80s because the stock pickups aren't thought of particularly highly... it's the wood most people are interested in!
i'd get some nice PAF copies myself.. maybe look a bit further afield than Gibson, but you don't need to spend a lot to get a lot!
fatherjones
PostPosted: Sat Mar 29, 2014 5:19 pm    Post subject: Reply with quote
Interesting. What about the switches, pots, circuit board, etc.... You guys saying give it the whole proper electrical transplant?
Mono
PostPosted: Sun Mar 30, 2014 3:24 am    Post subject: Reply with quote
I do, most have. There is no added value to keeping the PCB in. Bear in mind, CTS pot shafts are 1-2mm wider than the stock Japanese ones, so you need to widen the holes VERY CAREFULLY - use sandpaper wrapped around a pencil, and keep checking to see if it's wide enough as you go.
PostPosted: Sun Mar 30, 2014 4:45 am    Post subject: Reply with quote
or use alpha pots...
Mono
PostPosted: Sun Mar 30, 2014 4:51 am    Post subject: Reply with quote
mark you are too pragmatic for my liking!
PostPosted: Sun Mar 30, 2014 4:55 am    Post subject: Reply with quote
I dont trust my sandpapering...
Mono
PostPosted: Sun Mar 30, 2014 5:48 am    Post subject: Reply with quote
i actually did it with a step-wise router drill bit locked into my handheld screwdriver... very slowly
Reborn Old
PostPosted: Sun Mar 30, 2014 2:08 pm    Post subject: Reply with quote
Round knife sharpening files that have tapered ends work well also.
Modern Premium Tokais already have upgraded pots/harnesses, FWIW.
PostPosted: Sun Mar 30, 2014 2:12 pm    Post subject: Reply with quote
I liked the Gotoh PAF zebra in the bridge, the neck pickup was lifelss on my 1979 LS80.
I put a set of 1980 DiMarzio PAFs in there and love it.
Regards, Geoff
fatherjones
PostPosted: Sun Apr 06, 2014 7:18 am    Post subject: Reply with quote
My tech put a set of Duncan '59s in there with nickel covers -- kept the original wiring otherwise. Sounds great. Much better than the original pickups.
ChrisB
PostPosted: Tue Apr 22, 2014 12:27 pm    Post subject: Reply with quote
Nice wood like that deserves bringing the best out of it - I would swap the pickups and pots. I did and have no regrets.
PostPosted: Wed Apr 23, 2014 4:25 am    Post subject: Reply with quote
Original Tokai pups either GOTOH either 57 PAFS are on 8 K and even on 9 K range so would think about them as hot PAFs. They have some features not PAF related like the wires connecting to pots being wire insulate not braided. I can say I just tried 57PAF set yesterday and have to say I liked those a lot. Very clean sounding maybe Alnico V.....
I will try an Alnico set in a few days I guess Dr. Vs either Marshallheads.....
I have canged the pickups on my Tokai Love Rocks and Reborn with sucess.If the guitar is very good and has it, it is an improve in my experience.... Stock pickups are good enough however I can say.
Bluefinger
PostPosted: Wed May 07, 2014 8:39 am    Post subject: Reply with quote
I changed the PUPs in my '80 LS80 as well but haven't found the right ones yet. I had a set of SD '59 but they were too dark. Now I have Classic 57s but they are a bit harsh. I think I'll try SD Antiquities next ...
