1980 LS-120 $2500 USD OBO
Goto page 1, 2, 3  Next
scoville
PostPosted: Tue Mar 18, 2014 1:14 pm    Post subject: 1980 LS-120 $2500 USD OBO Reply with quote
1980 Tokai LS-120 "Les Paul"
Some nicks and dings but in great shape with very little play wear.
Neck very straight, 2 tuner shafts very slightly bent, work fine and hard to see. Almost no fret wear. I got this directly from Japan nearly 10 years ago.
http://users.burlingtontelecom.net/~scoville@burlingtontelecom.net/tokai/Tokai%201980%20Les%20Paul.html
links at bottom show routes in detail.
Comes with nice SKB hardshell case.
I'll ship anywhere, you pay actual shipping. I'm in the North East USA.
Chris
scoville@alum.rpi.edu
PostPosted: Wed Mar 19, 2014 11:16 am    Post subject: Reply with quote
PostPosted: Wed Mar 19, 2014 12:16 pm    Post subject: Reply with quote
That's real nice.
PostPosted: Wed Mar 19, 2014 1:48 pm    Post subject: Reply with quote
solid or veneer top?
scoville
PostPosted: Wed Mar 19, 2014 3:20 pm    Post subject: Reply with quote
It looks like a solid top but I'm not 100% sure.
In the right light you can see the wood grain of the pickup route continue up to the top surface. There is a very thin layer on top that looks to be be just the clear finish. Are there pics of a known veneer that I can look at and compare with?
PostPosted: Wed Mar 19, 2014 4:06 pm    Post subject: Reply with quote
If you can see the top grain running into the pickup cavity from the side of the cavity, then it's solid....
ampmaker
PostPosted: Thu Mar 20, 2014 4:34 am    Post subject: Reply with quote
I've got one, but this place doesn't allow attachments. PM me with your email address and I'll email you the photo (which is very clear).
It's not just the grain, but the position of the joint. Basically, with the pickup(s) out, look to see if the centre-seam of the top surface lines up directly with the joint you can see in the pickup cavity. If it doesn't, then naturally, it's a veneer on the top.
If it does, there's still a chance that there's a veneer - just possibly the underlying maple also had a perfectly aligned centre-seam. (Unlikely?)
PostPosted: Thu Mar 20, 2014 4:35 am    Post subject: Reply with quote
i have seen a lot of 120 veneer tops with a perfectly matched centre seam, thats why the pu cavity side grain continuation is a better indicator..
PostPosted: Thu Mar 20, 2014 4:47 am    Post subject: Reply with quote
I own an early 1980 120 with veneer. The veneer itself is too thin to be visible without sanding it a bit. It is also perfectly center seamed with the maple underneath.
As Mark says, flame running from top into the side cavity wall, is the best positive ID for a solid top.
PostPosted: Thu Mar 20, 2014 8:30 am    Post subject: Reply with quote
PostPosted: Thu Mar 20, 2014 8:31 am    Post subject: Reply with quote
PostPosted: Thu Mar 20, 2014 8:49 am    Post subject: Reply with quote
What are those pics showing???
PostPosted: Thu Mar 20, 2014 8:55 am    Post subject: Reply with quote
I don't know either
scoville
PostPosted: Thu Mar 20, 2014 9:23 am    Post subject: Reply with quote
simply the neck pu route.
PostPosted: Thu Mar 20, 2014 9:33 am    Post subject: Reply with quote
doesn't help, pretty tho..
Page 1 of 3
