Replacement bridge and tailpiece on 1982 Love Rock
misterhabit
Active member
Hello All, I have a 1982 Love Rock LS-50 that I am considering replacing the bridge and tailpiece. Does anyone have any suggestions or sizing recommendations?
Thank you...
Would this work?
http://www.ebay.com/itm/NEW-TonePros-PreNotched-Metric-TuneOMatic-Bridge-T3BT-N-Nickel-/230781181215?_trksid=p2054897.l4276
"Metric size: bridge = 73,6mm studs spacing - 4,2mm holes diam"
Would this be the correct replacement size for a 1980 LS 80 as well ?
I'm thinking of the ABRM-59BA, Nickel plated, natural brass saddles - Aged would do nicely, if so.
Problem I'm finding is the curved radius (12)? has flattened out somewhat and the G string is starting to choke.
Guess it's a symptom of age as a slightly older Yamaha SG showed the same signs ......
