Tokai ST-80
Mono
PostPosted: Thu Jan 30, 2014 4:52 am    Post subject: Tokai ST-80 Reply with quote
Hi guys
Not usually a strat fan at all... have owned 1 before and just didn't get on with it.. but this ST-80 popped up on YJ for a must-have BIN price, so I nabbed it.
http://page11.auctions.yahoo.co.jp/jp/auction/n127267453
There are some detailed shots in the link on the auction. Serial seems to be 0005975 (bit of corrosion on the first digit though)
So is this a legit 1980 ST-80?
PostPosted: Thu Jan 30, 2014 5:08 am    Post subject: Reply with quote
he says 80 on the fretboard, but cannot see it well in the pics, could be a 6 or an 8,
E pickups are correct, body looks to be 2 piece centre seam,
conclusion
probably an 80 but could be a 60
if the neck is a pronounced V its an 80,
if the stamp is indeed an 8 and the neck and body codes match then its deffo all an st-80,
if the body codes dont match and the body finish is nitro its an 80,
if the body is poly its a 60 .. possibly with an st80 neck
have to wait and see when it arrives andy, but more likely than not an 80
Mono
PostPosted: Thu Jan 30, 2014 5:12 am    Post subject: Reply with quote
thanks for the thorough rundown mark, i was on similar lines really
my mind tries to convince me theres an 80 on the board but i need to see for myself to be sure. never seen poly wear like that though... and my nitro te85 has similar crush/dent marks from light knocks
we shall see
Len
PostPosted: Thu Jan 30, 2014 5:15 am    Post subject: Reply with quote
It?s legit. Congrats
For me the A-Code in the body cavity is the indication for it being a ST-80
The wear on the neck laquer is also typical for a ST-80 that has been played a lot.
Mono
PostPosted: Fri Jan 31, 2014 10:45 am    Post subject: Reply with quote
thanks Len
I am still a little confused though... this page
http://www.tokairegistry.com/tokai-info/tokai-fender.html
seems to suggest that the serial number 0005975 would be a '54-'56 strat reproduction if it were an ST80... and yet rosewood boards showed up on vintage fender strats in 1958....
thoughts?
any other ST80s out there with rosewood boards and 4 digit serial number?
Len
PostPosted: Fri Jan 31, 2014 12:01 pm    Post subject: Reply with quote
I don?t know if I really get what you mean...
your guitar clearly is 1980-made and has a 7-digit serial number (the 000s count too! )
all 1980 - made tokais have a 7-digit serial, no matter if rosewood board or not
the whole thing with different serials for different fender models started in late 1981. first appearance of the new serial number system is in the 1982 catalog.
you cannot refer to that serial number system for a 1980 guitar
Quote:
Tokai Fender Replica Time Line
This information is from the 1982 Catalog.
fletspa
PostPosted: Sat Feb 01, 2014 6:12 am    Post subject: Reply with quote
Hi Guys.
Just a minor point, but it has a single ply 8 hole pickguard. Aren't these normally on the early 57 maple boards? Love the guitar though, very envious
Steve
muccax
PostPosted: Sat Feb 01, 2014 6:48 am    Post subject: Reply with quote
i had a rosewood neck tokai with the same 8 hole pickguard ,,,
it had a plug like a maple neck ,,,, they made them like this at first and then later they came with the right kind of neck no plug and 11 hole pickguard
Mono
PostPosted: Sun Feb 02, 2014 12:20 am    Post subject: Reply with quote
thanks for the input guys... but i'm still a little confused.
8 screw pickguard
skunk stripe on neck
veneer rosewood board
seems like an odd combination of things for a Fender replica... no?
or were early 1980 springys just a mixed bag of features?
(the thread that has confused me is this one: http://www.tokaiforum.com/viewtopic.php?t=21133&postdays=0&postorder=asc&start=15)
muccax
PostPosted: Sun Feb 02, 2014 3:41 am    Post subject: Reply with quote
hi
yes funny combo .... but i saw someware that fender made a neck like that
but a rare feature on a fender neck too
i only see the 8 hole scratchplate on the early ones ,,, before 1980 in 81 the got the 11 hole scratchplate and no plug neck
and the correct 1954 2 piece tremolo
all the best
otto
Sat2013
PostPosted: Sun Feb 02, 2014 5:13 am    Post subject: Reply with quote
Congrats.
neck and body ,main parts all 80 spec!.
players cond guitar but fair price.
Sat
PostPosted: Sun Feb 02, 2014 4:42 pm    Post subject: Reply with quote
To be clear, no neck made with Rosewood and skunk was a slab neck - regardless of Model. The slab was only produced after mid-1980.
The 8-screw plate was a common feature on both maple and rosewood up to early 1980 when the 3 ply 11-screw plate was introduced.
For the neck to be original, the end stamp would need to have an 'A' stamp after the number. On the body, the stamp should be in the front pickup cavity and should be close to this : 10=9 GS A. Neck should correspond 10=9 A.
Tuners should have 'TOKAI' stamped on them and have a locating pin beside the shaft. Truss rod would be Allen key. String saddles should also be stamped 'TOKAI'
Please keep us informed and post some pics when it arrives.
fletspa
PostPosted: Sun Feb 02, 2014 5:01 pm    Post subject: Reply with quote
Hi Guys,
Following on from Peter's comments and also disproving my earlier comments posted. I was drooling over a few guitars on the Japan Guitar web site and spotted this. http://s765.photobucket.com/user/generalunrest2/library/tokai/Tokai%20ST-80%20TBB%201978%20no%20logo?sort=3&page=1
8 plate scratch plate, rosewood board and skunk stripe.
As Peter states the Tokai true F Strat clone was obviously late 1980, so looks like you got nice Tokai there. Well done!!
PostPosted: Sun Feb 02, 2014 5:28 pm    Post subject: Reply with quote
Sorry fletspa,
I have always maintained that YM1982 are the most accurate Fendah replicas that Tokai ever made.
The final point was changing to F-style serial numbers of the year being replicated, correct scratchplates for 1952-59, 59-63 and 63-69 style, rosewood and maple necks are period correct and last year of spaghetti logo.
Keep in mind that, like the US, Tokai employed late-year Model launch, so 1982 featured guitars were relaeased in late 1981 and so on.
fletspa
PostPosted: Sun Feb 02, 2014 5:46 pm    Post subject: Reply with quote
Peter Mac wrote:
Sorry fletspa,
Cheers Peter, I stand corrected
