LS85 Goldtop
Goto page Previous  1, 2
Sjofar
PostPosted: Wed Aug 21, 2013 12:40 am    Post subject: Reply with quote
Yep, and I used the Original screws.
TalboA150
PostPosted: Fri Aug 23, 2013 2:30 am    Post subject: Reply with quote
Thanks. Might change mine too....
TalboA150
PostPosted: Fri Sep 06, 2013 4:43 pm    Post subject: Reply with quote
Sjofar wrote:
Latest upgrades:
Switchcraft toggle switch & output jack
Nickel output jack plate
Sprague orange drops
What do you suggest: Gibson Classic 57(+), Gibson Burstbuckers or Dimarzio 36th Anniversary humbuckers
Any noticable difference with the orange drops? Did you keep the original pots and wiring in there?
Sjofar
PostPosted: Tue Sep 17, 2013 3:22 pm    Post subject: Reply with quote
I kept the Original pots and wiring, perhaps in future I'll replace the wiring.
No use to change the pots, they're allways on 10........
Guitar sounds a little brighter (I think!).
dombat
PostPosted: Tue Sep 17, 2013 4:21 pm    Post subject: Reply with quote
absolutely no reason tio be brighter with a pot at 10... maybe at 11?
Sjofar
PostPosted: Tue Sep 17, 2013 11:33 pm    Post subject: Reply with quote
Well, it wasn't expensive and it didn't cost much time, so I thought: why not?
Sjofar
PostPosted: Mon Dec 02, 2013 5:41 pm    Post subject: Reply with quote
Latest upgrade:
Faber Alu Tailpiece (TP-59NG, Vintage Spec ALU Stop Tailpiece, nickel, gloss)
gordon
PostPosted: Tue Dec 03, 2013 9:43 am    Post subject: Reply with quote
The Stormy Mondays are very open/vintage sounding, don't know what tone you're after.
I have them in my ES-335, would look for more punch in a LP.
6 strings are more than enough
gordon
PostPosted: Tue Dec 03, 2013 9:48 am    Post subject: Reply with quote
By the way the Reverend BFG plays 008 strings. Or even skinnier. That's due to his health. Sounds pretty mean and powerful still.
I play .046 / .010 as well but you can fool around with string tension adjustment quite a bit in setting up a LP.
Sjofar
PostPosted: Thu Mar 20, 2014 2:25 pm    Post subject: Reply with quote
Update:
I now use Gibson Les Paul Signature strings (0.09-0.46), so smooth!
New nut from Graph Tech and a set of Gibson Burstbuckers 2+3, to my humble opinion they do sound brighter than the stock pickups.
Anyone (in the neighbourhood) interested in the stock pickups?
Sjofar
PostPosted: Thu May 22, 2014 10:33 am    Post subject: Reply with quote
The final version:
with Gibson historic washer, pickup mounting rings, pickguard and toggle switch cap.
Also replaced complete wiring.
Only originals are body, neck and pots.
Diamond
PostPosted: Thu May 22, 2014 1:08 pm    Post subject: Reply with quote
Do your strings touch the back of the bridge?
Sjofar
PostPosted: Thu May 22, 2014 1:40 pm    Post subject: Reply with quote
No, because I use this kit:
http://www.tokaiguitar.de/produktdetail.php?id=15
Page 2 of 2
