Rewiring my 1981 ES-100R, look what I found..
PostPosted: Sun Jul 28, 2013 4:09 am    Post subject: Rewiring my 1981 ES-100R, look what I found.. Reply with quote
I had a faulty pickup selector switch and wanted to change the pickups, so I chose to swap the complete harness while I was at it.
First surprise when I took out the original harness; mini pots!
Second surprise; PIO caps, the same as seen on LS-150 & 200 of that era.
Third suprise; no direct wiring of the pickups wire on the pot but via an extra lead attached to the pot. Not very classy.
Fourth surprise; I didn't have to enlarge the holes for the pots; the CTS pots did fit exactly!
Tip; when using the standard Switchcraft selctor switch, you need a broad ring for the threaded part of the switch will not pass through the hole in the top.
Here are some pics;
PostPosted: Sun Jul 28, 2013 7:39 am    Post subject: Reply with quote
Interesting.... some times you really don't know what is there until you look under the hood....
Chesterreddragon
PostPosted: Thu Aug 15, 2013 12:21 am    Post subject: Reply with quote
That's a great looking ES100R, quite a different shade to mine. How do you rate the magnatone amp?
ES100R
LS95s
LS105Q
TTE-50
Greco SS500
Gibson Jeff Tweedy SG
Various vintage and modern valve amps -Selmer, WEM, Vox, Fender.
PostPosted: Thu Aug 15, 2013 8:37 am    Post subject: Reply with quote
Thanks!
The Magnatone is a 1957 260 model, so it has 12AX7s in preamp and 5881s as power tubes. Sounds somewhat like an early plexi to my ears, so a dark sounding amp except it's a little more spongey because of the wood used for the cabinet. A bit more boomy bass and somehow takes pedals and humbuckers less well than a plexi. On the other hand the vibrato is out of this world beautiful, never have heard anything like it.
Sold it 6 weeks ago
Chesterreddragon
PostPosted: Thu Aug 15, 2013 12:46 pm    Post subject: Reply with quote
Beautiful amp
ES100R
LS95s
LS105Q
TTE-50
Greco SS500
