Does the weight of a guitar influence its sound?
Joop
PostPosted: Sun May 26, 2013 5:19 pm    Post subject: Does the weight of a guitar influence its sound? Reply with quote
I came accross the following video about an original '59 Gibson Les Paul
http://www.youtube.com/watch?v=sX5wMTdE2PQ
In this video the guitarist (Michael Caswell, famous a.o. from LickLiberary) remarks on how light weight this original 1959 Les Paul is and that all 3 originals that he has been able to lay his hands on, all have been light in weight. He states that it makes the guitar more resonant..
What is your experience? Do guitars on the lower spectrum of the scale (say up to 3,5kgs) sound better than their heavier counter parts?
I can immagine that a guitar with less weight is easier to gig with but I want to exclude that argument.
I want to know the influence the weight has on the sound of the guitar because before seeing the video, my thought would be that a heavier guitar would be more resonant and able to produce fuller tones and perhaps even able to produce more sustain...
Look forward to reading your comments..
Cheers!
Joop
Vintage tones requires time, not technology....
PostPosted: Mon May 27, 2013 12:52 pm    Post subject: Reply with quote
Yes it does. Lighter Les Pauls (3,7 kg.-4 kg.) sounds different than over 4,3 kg.
Some prefer lighter ,some prefer heavier. I have both and I can say I like both, my best Love Rock is heavy. But I like my LS-50 which is the lightest of all my Love Rocks,it does that crunch sound the best.
If the guitar weights lower than 3,6 it would have bass sound missing altough there are several tricks to get some back.
If we are talking about sustain then a Hibiki HLS has something special on it (4 kgs mine) with a great attack and fast sound travel.It hassomething about how Tokai designed more than the weight here.
Your best choice is getting one of each .
davejm
PostPosted: Wed May 29, 2013 5:47 pm    Post subject: Reply with quote
Just wanted to say Thanks for the link, Joop.
What always amazes me is how all modern Gibson LPs look so obviously different from the beautiful lines of original LPs - and not just the obvious absence of the old carve - especially noticeable in a vid where the movement displays the whole guitar - that guitar looks 'lean' and sculpturally pleasing in a way they simply don't now; there must be design nuances that have just been coarsened over the years.
Not so much a fan of power chords as ambiguously semi-discordant, heavily finger vibrato'd lead gtr screechings at the far end of the neck: more Williamson than Gurley, though.
CliffsComicWorld
PostPosted: Wed May 29, 2013 10:35 pm    Post subject: Reply with quote
For me.......
The heavier the guitar over 9 lbs. = Better bottom end sustain Rock sound.
The light end under 9 lb. = Loss of bottom end and more mid/treble.
Trouble is ... I prefer a lighter guitar and the sound of a much heavier LP
My 2 cents
Vignale
PostPosted: Sun Jun 02, 2013 4:32 am    Post subject: Reply with quote
Some 25 years ago I was a luthier and I then always preached: the more heavy a guitar weighs, the more sustain.......
I thought like this: Imagine bolting or gluing a neck to a "sleeper" (You know: the wooden parts under trainrails)
The strings would chime longer than when glued to a sigarbox
What I also learned: maple and other hardwoods have a tight cellular density and give more high overtones, while softer tone woods like mahogany give more warmer tones because of more wide cell density.
I also found out, since I had build an explorer that sustain comes from the length of the body-wood. (it had a Indian rosewood top and Mahogany back)
An explorer has these long "horns" and the tone goes from one end to the other end of the body and back.
Since many people say that light LP's have a longer sustain I thought I was wrong in my opinions and found that light LP's do sustain equally well......
I think this has to do with the rest of the mathematics of other parts like strings bridge neck etc.
There's an end to the string vibration somewhere even when stringed on the most sustainable wood there is.....
Light LP's might just have this mixture of selected woods and mathematics that is minimal required for the max. sustain.
Hope you understand what I mean.
The above might be a lot of b.....s.....t but it's JMHO.....
Let me know what you think.....
Cheers,
Chris.
Tokai LS1000, Tokai LS60/70 (83) Tokai Reborn old LS50, Tokai Limited edition, Tokai Goldstar, Tokai Cat's eyes CE800, Greco ES175, Ibanez PL2550 etc.
CliffsComicWorld
PostPosted: Sun Jun 02, 2013 10:59 am    Post subject: Reply with quote
Right on Chris... Thanks for your input!
StugIII
PostPosted: Mon Jun 03, 2013 3:53 pm    Post subject: Reply with quote
Weight is just a factor in tone equation. Two parts we have to consider separately: neck and body, because there are important differences in mass effect between both.
Lighter guitars are more resonant than heavier ones, anything else being equal. Lighter wood means less energy required to excite resonances. Also, physics explain that lighter guitars resonate at higher frequencies than heavier. Neck play a paramount role in resonance, while body just modulate neck vibrations. Heavier bodies mutes neck resonances. And heavier necks resonate at lower frequencies than lighter ones.
So, a light neck and a light body usually resonates too much and at higher frequencies. Has potential for a lot of sustain, but tone may be too airy. Usually this is not good for bass notes but add some richness to the tone of high notes.
A heavy neck a a heavy body has a poor resonance, but much clarity and attack.
A heavy neck and a light body usually have both resonance and deep bass tones and is my personal preference for a good woodier tone.
Regarding to sustain: it depends on the transmission from the strings to the body. The lesser, sustain increases but also resonance is reduced and hence, tone lack woodiness.
But transmission heavily depends on the bridge design and mass, so guitar mass is not the decisive factor here.
bluejeannot
PostPosted: Mon Jun 03, 2013 5:24 pm    Post subject: Reply with quote
http://www.frudua.com/guitar_craftpedia_en.html
Here`s some interesting info about guitar construction from an Italian luthier . He really seems to know his stuff Gabe.
bluejeannot
Thomas/Sweden
PostPosted: Tue Jun 04, 2013 7:31 am    Post subject: Reply with quote
I was surprised when I got my OBG LPC-57B Custom, it's only 3,4 Kg and very resont but still full LP sound with enough bass. It was a bit strange at first with a Custom this light but it plays and sounds great (57 classics).
PostPosted: Tue Jun 04, 2013 7:55 am    Post subject: Reply with quote
I've had quite a few Les Pauls, some heavy and some light and they all sound 'different', but IMO there are too many other factors to consider (hardware, pickups, construction), and the way a guitar sounds is a sum of all of these so it's really difficult to say what effect weight alone has.
