Love Rock ID
B-Nads
PostPosted: Sat Mar 23, 2013 1:06 am    Post subject: Love Rock ID Reply with quote
Hi - was wondering if I could get some help id'ing this Love Rock. I suspect it's a MIK...TRC, pickup route and bridge are wrong for MIJ. The neck pup only has an F stamped on it, and the bridge is stamped Epiphone. The finish is undoubtedly nitro though...I wasn't aware MIKs were done in nitro. It has a short tenon, but the neck has the offset to the left. There are no numbers. The neck has a scarf joint. Any help would be much appreciated.
Thanks.
[img]http://i816.photobucket.com/albums/zz84/brent-gk/2012-08-17065[/img]
PostPosted: Sat Mar 23, 2013 10:52 am    Post subject: Reply with quote
You are correct, not MIJ Tokai.
dombat
PostPosted: Tue Mar 26, 2013 9:16 am    Post subject: Reply with quote
Scarf joint=made in china
Reborn Old
PostPosted: Tue Mar 26, 2013 3:46 pm    Post subject: Reply with quote
I'm pretty sure it is MIK, probably dating to somewhere around 2002 based on TRC style and lack of a MIK headstock ink stamp.
Certain MIK models and years have scarf jointed necks.
Unless the serial number was removed, it wouldn't have been made in China.
Nitro finish is extremely unlikely unless stripped + refinished by a 3rd party.
How did you test for nitro finish ?
niva
PostPosted: Thu Nov 17, 2016 3:13 pm    Post subject: Reply with quote
Hello there!
I am the current owner of this particular guitar. I am still wondering if it is a MIC or MIK. But the pick-up cavity has the two holes like the MIJ ones...
Any information would be appreciated.
Thanks!
Paladin2019
PostPosted: Fri Nov 18, 2016 6:40 am    Post subject: Reply with quote
My money is on an older MIK. The hardware (metal and plastic), neck joint, and truss rod cover are all wrong for MIJ and a Chinese model or recent MIK would have a serial number and dimpled headstock shape (actually pretty rare to see an undimpled model that's not MIJ).
With that in mind the finish will definitely not be nitro. A burst refinish would cost more than the guitar when it was first bought, and why would you do something like that but fit leftover epiphone pickups? Plus the fact the the flame is a veneer, stripping the old finish would risk destroying it.
dombat
PostPosted: Fri Nov 18, 2016 11:54 am    Post subject: Reply with quote
All Tokai guitars sold or on sale in France, MIJ, MIK or MIC are undimpled !
niva
PostPosted: Fri Nov 18, 2016 8:25 pm    Post subject: Reply with quote
Here are some other pictures of the guitar:
capture
jpg images
screen cap
image upload no compression
img host
I also have GOTOH JAPAN tailpiece and bridge, Epiphone pickup on the bridge position (probably installed by the previous owner) and a WD pickguard. This guitar plays very nicely and is wel built. I am just curious to find where it is from and the approximate year.
For the "nitro" finish, I am not an expert but the guitar smell "smoky" and"sweetened" if I can say that.
Thanks for your help!
Guillaume
niva
PostPosted: Fri Nov 18, 2016 8:27 pm    Post subject: Reply with quote
... and anyone knows what the "F" stands for on the neck pickup?
PostPosted: Fri Nov 18, 2016 10:08 pm    Post subject: Reply with quote
F Stands for Front.
Paladin2019
PostPosted: Sat Nov 19, 2016 7:07 am    Post subject: Reply with quote
To me, the new pictures confirm everything I said before. MIK, early 00's most likely.
Poly finish, not nitro.
niva
PostPosted: Sat Nov 19, 2016 8:46 am    Post subject: Reply with quote
Ok fine!
Last question: from the last picture, you can clearly see that someone wrote "LS" on the edge of the neck. So I guess it's an "LS" model But how do I know if it is an LS-40, LS-45, etc?
Thanks again!
Guillaume
Paladin2019
PostPosted: Sat Nov 19, 2016 10:29 am    Post subject: Reply with quote
I wouldn't say that you can 'clearly' read LS on that neck. I'm not sure what it's supposed to be.
Having said that, if we run with the theory that it's an older MIK I would say it's an ALS48. There's a picture of one in the 2000 catalogue that looks identical to yours.
niva
PostPosted: Thu Dec 01, 2016 1:25 pm    Post subject: Reply with quote
Is it possible to identify which type of wood was used for the body and the neck/fretboard according to the pictures posted above?
Thanks again!
Guillaume
Paladin2019
PostPosted: Fri Dec 02, 2016 4:26 pm    Post subject: Reply with quote
Well, the fretboard is rosewood but the rest can't be identified by sight. The top is a veneer.
According to the 2000 catalogue the ALS48 has a maple neck and an alder body.
